Forscan: Global Window Open/Close
Old Nov 14, 2020 | 06:58 AM
Rjacks258's Avatar
Rjacks258
This forscan thing has gotten me wanting to do everything I can with out it being ridiculous.
Questions; under the global window portion, do I have to change all those values for it to work? Just making sure.
And under the IPC portion, that code is only for adding the “close window” check box in advance settings, correct?
I already have the “open window” check box and can open windows with the remote but nothing else.
There’s not too much else I can or want to do being that my truck is an XL/STX.
Old Nov 14, 2020 | 07:02 AM
System's Avatar
System
Prolocutor
Yes, you have to do them all and yes it will add the "close" checkbox.
Old Nov 14, 2020 | 07:06 AM
Rjacks258's Avatar
Rjacks258
Thanks man, just wanted to confirm that. Only messed with single values so far.
Old Nov 14, 2020 | 07:08 AM
System's Avatar
System
Prolocutor
I've done it on mine and works like a charm.
Old Nov 14, 2020 | 09:23 AM
Rjacks258's Avatar
Rjacks258
Sweet. Did that and added average speed display. Pretty cool.
Do these trucks only open front windows with the remote? Or is it because of the trim level? Noticed this before. Wife’s car does all 4 plus sunroof open and close.
Old Nov 14, 2020 | 11:50 AM
System's Avatar
System
Prolocutor
I think it's only fronts across all trim levels if I am remembering correctly...
Old Feb 20, 2022 | 08:40 AM
WLR's Avatar
WLR
We are trying to enable the global close on our 2022 F250 XL. I searched each module and thought I have it turned on everywhere, but still dosen't work. Global open works, but not close. Am I missing something simple?
Old Feb 20, 2022 | 11:19 AM
4wd6.7L's Avatar
4wd6.7L
If you followed and completed the changes from the spreadsheet, and you're pressing the lock button once and holding it but it's not working, I'm not sure what it could be. Is there a check box in the menu that needs to be checked?
Old Feb 20, 2022 | 01:11 PM
WLR's Avatar
WLR
Got it! Missed one place in BCM !! Global windows now works!
Old Jul 6, 2022 | 03:13 PM
cpobst's Avatar
cpobst
So just to verify, this only works on the front windows correct? Sure would be nice if the rears did it also. Mainly for global close when it starts to rain out of nowhere and your windows are cracked because its 100 degrees outside. Yes that just happened to me.....
Old Jul 6, 2022 | 03:22 PM
thatxjguy's Avatar
thatxjguy
It works on any Ford vehicle windows with one-touch down. On most of all super duties, I think that’s the fronts.
Old Jul 6, 2022 | 03:49 PM
jasoncw's Avatar
jasoncw
Exactly. Two examples:
I have a 2013 Fusion that has 4 window one-touch switches. The auto up and down works on all 4 windows.
I have a 2017 SHO that as 2 window one-touch switches (front only). The auto up and down only works on the front windows.
My assumption based on this is the Super Duties will only work on the front windows.
Old Jul 6, 2022 | 06:22 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
I did the average speed display a few years ago. No matter what, it always shows average speed as 26mph.
oh well…
Old Jul 6, 2022 | 06:31 PM
thatxjguy's Avatar
thatxjguy
oh well…
Sounds like a similar issue to me. Mine shows a static speed as well, and it never seems to change despite my crazy driving.
Old Jul 7, 2022 | 10:24 AM
chadstickpoindexter's Avatar
chadstickpoindexter
On the 22MY Super Duties only the front driver and passenger side windows globally open and close (you have to enable the close option with Forscan though). It would be nice if all 4 windows (5 including the rear sliding window) would globally open and close though… Also, the front driver and passenger windows are the only ones that have the auto up/down.
I also enabled the average speed and it seems to work on mine. I sometimes remember to reset it when I am filling up, but it seems to be pretty accurate.
