tachometer swap
Old 09-28-2000, 07:05 PM
n0tst0ck's Avatar
n0tst0ck
n0tst0ck is offline
tachometer swap
for those of you interested in installing a factory tach into a 93-96 f-150 it is really easy. i obtained a used cluster w/tach for $85, removed mine, swapped the speedos out to keep the same mileage and had it all back together in under an hour. any questions, e-mail me a n0tst0ck(No Email Addresses In Posts!).
Old 10-10-2000, 09:16 PM
95xltmud's Avatar
95xltmud
95xltmud is offline
tachometer swap
so if i go to a junk yard and get a cluster from a truck with a tach it wont be hard at all to swap and i can retain the same milage?
Old 10-10-2000, 09:29 PM
hotrodford_88's Avatar
hotrodford_88
hotrodford_88 is offline
tachometer swap
Yes, it is a very easy swap. I had to run the mileage up on the cluster I bought, but other than that it was a bolt in swap. And Ford's techs said it Can't Be Done if it wasn't originally wired for it.
1988 F-150 Custom to XLT Lariat conversion, 5.0 EFI (formerly 300 I6), 5-speed M5OD, 3.08 rear gears (will be upgraded to 3.55's), Summit headers, Flowmaster muffler W/ dual 3.5" tips 24" long.
Pioneer CD, AC, Tilt, Cruise, Mobile Radio, Lightbar (Force 4 LP6000), Federal Signal PA300 Siren W/100W Siren Speaker. Caution Customizing in progress, Watch for flying tools & Parts!
Old 10-10-2000, 10:45 PM
hotrodford_88
tachometer swap
Also forgot to mention. If those of you who don't have iterval wipers on your trucks (80-91, don't know about 92 & up)
You can add them! Ford told me no way can't be done! I proved them wrong. Just go to a wrecking yard, get the interval switch, wiring and control box, and you're all set. It only took me about 30 minutes to do this swap on my truck. And I definitely like interval wipers better than running down the road in a misting rain with the wipers going constantly.
Old 10-11-2000, 08:19 PM
n0tst0ck's Avatar
n0tst0ck
n0tst0ck is offline
tachometer swap
yes you can keep same mileage readout...the speedos are the same for the 2 clusters they just plug in.
Old 10-11-2000, 08:21 PM
n0tst0ck's Avatar
n0tst0ck
n0tst0ck is offline
tachometer swap
you coulda just swapped speedos while u were in there they just plug in.
Old 10-11-2000, 08:28 PM
hotrodford_88
tachometer swap
I know, but my original cluster was the base model. And I wanted the trip meter. So, I just pushed the tabs on the odometer numbers back, and ran the numbers up to match the current mileage. No, problem and there was nothing illegal about (at least I don't think there is anyway)
I'll probably keep this truck until it falls apart anyway, so I'm not going to worry about it if I sell it.
Old 10-11-2000, 11:04 PM
95xltmud's Avatar
95xltmud
95xltmud is offline
tachometer swap
About how much do you think a cluster would cost at a junk yard, or more specifically, how much did you have to spend?
95xltmud's Avatar
95xltmud
95xltmud is offline
tachometer swap
nevermind that last post, i realized you wrote that in the original message.
Old 11-30-2000, 05:27 PM
laka's Avatar
laka
laka is offline
tachometer swap
I have a 90 Custom, it has the most basic cluster, not even a triptometer, does anyone know if this swap is just as easy for the earlier than 93 dash style trucks
thanks
Old 11-30-2000, 06:26 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
tachometer swap
Hey Hotrod, I have a 1989 F-150 XLT that has the base speedo. I know that the 92 and newers use a electronic speedo, but is it possible to use one in a pre-92? The look identical.
Pastmaster's 1993 XLT 5.0 E40d 3.55LS Normal Cab/Long bed Loaded from the factory with aid of...MSd 6a ign/s.p. wires, blaster coil, Hypertech Chip, K&N filtercharger, Cat-back dual exhuast w/o mufflers, 3.5", echo tips, Accel distributor cap, Dark Mocha over light mocha. 5% Dark tint, Alpine Cd player/remote, Pioneer speakers.
toydestroyer1(No Email Addresses In Posts!)
Old 12-01-2000, 08:50 AM
hotrodford_88
tachometer swap
I don't think the newer style clusters will fit, You all probably know by now how Ford is with changing wiring around right?
I bought the entire wiring harness for under the hood out of a 91 model. Only one slight problem. When I turned on the ignition switch, the headlights came on with the fuel pump. They came on for a second & went out. Everything else worked though but, If I had left the truck running the headlights stayed on too!
Just a little hint of what Fords evil minds came up with.
Good luck ya'll. I bought mine out of a 90 model I think and it works perfectly. All except that darn fuel guage. Always reads less than whats in the stinking tank!
"You can always tell a Chevy owner, You just can't tell them very much."
Old 12-02-2000, 01:11 AM
gharmon's Avatar
gharmon
gharmon is offline
tachometer swap
HIO Silver
Testing.....
10-02-2015 12:36 PM
kbbagshaw
1999 to 2016 Super Duty
08-23-2015 10:43 PM
ptut42
06-03-2014 03:31 PM
Shorthair49
03-27-2014 08:19 PM
Quick Reply: tachometer swap
