2020 Regen?
Old Nov 12, 2020 | 12:05 PM
2020KR350's Avatar
2020KR350
2020 Regen?
Does the 2020 show when it goes into regen on the dash like my 2012? I have never seen any indication that it has did a regen in the 5800 miles that I have driven it. Also I used Forscan to have it display the % full of the DPF and it has never come off of zero. Dealer is going to look at it Monday when I bring it in for them to throw more parts at my on going electrical issues.
Old Nov 12, 2020 | 01:37 PM
stimpee's Avatar
stimpee
I have not seen any indication of regen on my new 2020 F450, but I have used maybe 25% of my DEF, so clearly it has done regen in the first 1000 miles of driving.
Old Nov 12, 2020 | 01:40 PM
ford390gashog's Avatar
ford390gashog
The regen doesn't involve using DEF. These trucks do not show anything unless the screens are enabled. The 20's do use more DEF but less EGR.
Old Nov 12, 2020 | 02:17 PM
Tearitin's Avatar
Tearitin
I had to turn it on using Forscan on my 2020. It will then show up under the maintance window as to the % of of DPF filter, when in regen it foes down about 5% a minute plus you can smell it. I also enabled Manual Regen so I didn't have to drive around for 20 minutes while the regen completes.
Old Nov 12, 2020 | 03:55 PM
2020KR350's Avatar
2020KR350
My DPF % has not come off of zero.
Old Nov 12, 2020 | 04:00 PM
SARDiverDan's Avatar
SARDiverDan
Why drive around, just park the truck. The truck will regen the next time you drive it.
Old Nov 12, 2020 | 08:19 PM
senix's Avatar
senix
shutting the truck down during the regen leads to excessive oil dilution and shutting down a hot turbo.
At least let the truck idle a few minutes.
Old Nov 12, 2020 | 08:20 PM
senix's Avatar
senix
Do a lot of towing? I haven't had a regen in at least 800 miles. towing will make it passively regen.
Old Nov 13, 2020 | 07:09 AM
corey4's Avatar
corey4
I have a 20 with 1300 miles and have not noticed a regen yet. I do a mix of towing on highway and city and empty highway and city, long trips and short trips.
Old Nov 13, 2020 | 08:14 AM
mwebster22's Avatar
mwebster22
how can you know if it is regening?
Old Nov 13, 2020 | 08:17 AM
senix's Avatar
senix
With a monitor such as the banks idash.
My model also has a setting to shut off auto regen.
It will prompt you when full.
Old Nov 13, 2020 | 11:03 AM
hindy's Avatar
hindy
Like many here... I know the system is suppose to do a regen every 500 miles. I currently have 2300 on mine and just experienced a regen in the last 100 miles. The only way I noticed a regen was happening, is when my MPG were going down and the truck stayed in 9th gear when usually along the same route, it drops into 10th. When I arrived home, I could smell (for the first time) a regen happend or is happening. Don't know if the regen finished or not. I'm one wanting to know everything going on with the truck so I may have to turn something on to indicate a regen.
Old Nov 13, 2020 | 12:48 PM
maxum96's Avatar
maxum96
The only way I know my truck is doing a regen is by watching the exhaust temps on my Torque phone app that's bluetoothed to the truck. Exhaust sensors 13 and 14 will show around 1100 degrees during a regen. Otherwise they go no higher than about 800 degrees, even while towing up hills.
Flitastic
Sep 30, 2019 09:03 PM
eastern ecobooster
2009 - 2014 F150
Aug 18, 2014 06:16 PM
55fordv8
2011 - 2019 Explorer
15
Feb 9, 2014 05:18 PM
onedcharette
Nov 27, 2012 01:41 PM
