Antenna question
Old Nov 12, 2020 | 11:32 AM
sdchosen1's Avatar
sdchosen1
Antenna question
I am looking for a replacement antenna for my 65. The prior owner removed it for a sleeker look and put a rubber grommet in it which is fine but I am wanting to have the factory antenna look. Was wondering what the difference in these are besides price.
Parts geek antenna
CJ Pony Antenna
Carolina Classics Antenna
Old Nov 12, 2020 | 11:46 AM
robertrpeak's Avatar
robertrpeak
They look the same, except for a big difference in price. Think I'd try the cheap one and see if it works for you.
Old Nov 12, 2020 | 01:45 PM
ibuzzard's Avatar
ibuzzard
See A Man About A Horse
I would not consider the first one, it appears to be an “el cheapo“ universal one. Those usually fit like crap, not sealing well. The other two are repops that should at least fit, as they were designed for the specific vehicle, though they won’t be as well made as the original ( poor chrome, gasket materials, etc.) It’s likely , as with other repopped parts, that all vendors are sourcing these from the same place.
Old Nov 12, 2020 | 07:11 PM
BobbyFord's Avatar
BobbyFord
Carpenter has NOS for $89
It’s best to call or email and ask for the NOS.
Old Nov 13, 2020 | 11:17 PM
sdchosen1's Avatar
sdchosen1
Next question is do you install from the top. I opened the hood and I don't see anyway to get to bottom side of antenna. Then where do you run the cable to connect to the back of radio through?
Old Nov 13, 2020 | 11:27 PM
sdchosen1's Avatar
sdchosen1
And does the replacement antenna angle backwards. All the pics look like it angles toward the rear of the truck. Did the original angle backwards?
Old Nov 14, 2020 | 06:35 AM
robertrpeak
Yes, thru the top. Then thru a hole under the dash in the upper kick panel. Never seen one angle back, always straight up..
Old Nov 14, 2020 | 09:41 AM
ibuzzard's Avatar
ibuzzard
There’s a bit of adjustment to be had by loosening, then rotating the antenna, before retightening.
Ding126
Jun 1, 2020 09:43 PM
Chiefdan
Mar 16, 2019 09:54 AM
02-7.3D
Feb 2, 2011 06:41 PM
BigRed1
Electrical Systems/Wiring
Sep 14, 2008 09:37 PM
Gage2502
Jul 10, 2008 03:30 PM
