Water in the Glove Box
So we recently got rain in S. California this past Saturday after about 7 months of no rain. Today I went into the glove box and there was water. I did not find any signs of water anywhere else.
2 possibilities come to mind.
1. Sunroof drainage tube blocked
2. Leak in the windshield.
Both areas are so far away from the glove box. How could water travel all the way there? Headliner around the sunroof is dry. Behind the glove box and above appears to be dry. It's as though someone poured water directly into the glove box.
I'm going to have to break out the garden hose and run water over the cab to see if it repeats. Anyone have any other ideas on how water got in there?
Had the same issue with a car we had, it was the drains for the sunroof, poured a small amount of bleach and stuck lawn trimmer plastic wire down the cut it off and attached the cordless drill, tried to just fish out at first but it only lasted half a rain, after i used the drill it never came back.
The question that in my truck, the water traveled down into the glove box and nowhere else is quite a mystery.
I'll have to check it all out. Thanks for the help!
