help with disc brakes
Old Oct 23, 2003 | 09:03 AM
charliemccraney's Avatar
charliemccraney
Can anyone tell me what the diameter and thickness of F100/150('73-'93) 4wd front rotors is. I want to try to use 4wd front rotors on the rear of my 61 unibody so I can have 4 wheel disc brakes. I will use lincoln or cadillac calipers with the built in parking brake and fab mounting brackets. I want to maintain the 5 on 5.5" bolt pattern without having to drill the rotors everytime they need to be replaced. I want something that can be serviced easily with no or very few modifications needed and off the shelf parts. I have '73-93 f100/150 2wd rotors up front now and I don't want the rears to be larger than the fronts. I posted this in the 73-79 forum but I haven't had any luck.
Old Oct 26, 2003 | 07:13 PM
Putt's Avatar
Putt
You should be able to call a parts store that turns rotors and get the specs you're looking for.
lbumpers
Oct 10, 2014 10:44 AM
SuperDuty93
Dec 14, 2013 08:30 PM
rgoodell
May 17, 2013 09:30 PM
choochoof150
2004 - 2008 F150
Jan 1, 2011 03:30 PM
Twissted
Mar 21, 2005 02:51 PM
