Sponsored by: Auxito
Popping Noise
Old Oct 23, 2003 | 08:47 AM
karenj's Avatar
karenj
Popping Noise
Hey to you all, got an interesting post. A couple of friends of mine are experincing a "POP" when they crank their wheel to one side or the other. Like if you tried to turn your truck into a compact parking spot. Now, they both have 03' supercrew's w/ aprox. between 4k and 8k miles on them and 3.5" Fabtech spindal lifts.Everything has been re-torqued including the wheel bearings. The SPACERS that go on the lower control arms around the lower ball joints are also installed.Called Fabtech and they never heard of it , unless the SPACERS are not installed. Has anybody experienced this and where is the "POP" coming from and also what would be a fix for the problem.
Thanks a-lot for any info. on this, Rich
Old Oct 23, 2003 | 09:02 AM
Grimolfr's Avatar
Grimolfr
Years ago, my mother's car had a problem similar to this. (Although, without actually hearing/seeing the problem, I can't be certain how similar it may be.)
In her case, we had recently had the wheels re-aligned, and the mechanic didn't re-torque the A-frame after making adjustments.
Look for loose suspension parts or parts showing odd wear patterns (where there should be no wear.)
The way we finally found the problem with mom's car was to lay under the car and look while someone sat in the car and turned the steering wheel hard to the side. Watch for parts that move in directions they aren't supposed to.
Old Oct 23, 2003 | 06:06 PM
wineman691's Avatar
wineman691
I would be very careful during this process. Its nice to have the visual but its very dangerous to be under a jacked truck/car while its running
Old Oct 23, 2003 | 06:56 PM
karenj's Avatar
karenj
There are absulutly NO signs of wear, NO signs of anything showing an abnormal wear. The pop only sounds when the vehicle has all the weight on all four tires while turning sharp into like a parking spot, NOT jacked up. I know when you add spindals to lift a truck ,the lower ball joint has more stress on it due to the angle, thats why the shim is added over ball joint to take up the gap between the retaining clip and lower control arm.I'm thinking it would be that area to look at, but i'm not sure thats why i'm asking if anybody has experienced this pop. Thanks in advance, Rich
Old Oct 23, 2003 | 07:04 PM
Racerguy's Avatar
Racerguy
Does the noise happen only when the wheels are cranked as far as they will go to one side or the other or as they are being turned?
Old Oct 23, 2003 | 07:09 PM
karenj's Avatar
karenj
Yes only when cranked as far as they can go. I also thought it would be the turning stops on the spindals hitting the stops on the lower control arm??
Rich
Old Oct 23, 2003 | 07:13 PM
Racerguy's Avatar
Racerguy
Put a dab of grease on the steering stops and see what happens.
Old Oct 23, 2003 | 07:16 PM
karenj's Avatar
karenj
Ok I will try that and will get back to you. Thanks Dave
Rich
Old Oct 23, 2003 | 10:33 PM
Grimolfr's Avatar
Grimolfr
a) As already indicated, if this is the problem, it will only do it with weight on the tires. This is why it took us so long to figure it out.
b) It's a truck (this time), not a car. You don't have to jack it up to look underneath it. You just have to trust the person turning the stearing wheel not to put it in gear. (In other words, don't get your 12-year-old to help you diagnose.)
Old Oct 24, 2003 | 11:20 AM
karenj's Avatar
karenj
Racerguy,
Hey thanks for the Info. The dab of grease worked well. The 2 metals together when under presure,it had to give and that was the noise.Thanks again. Rich
Old Oct 24, 2003 | 10:56 PM
Racerguy's Avatar
Racerguy
Good to hear that it was just something simple
