Hello all, the stock radio that came in my truck is shorting out. I have a 1995 F250 XL with a 460 Supercab. The used stock radios are very expensive. I’m looking for suggestions on a Bluetooth cd radio receiver that is EASY to install. I am new to electrical wiring and learning on the go! So far I’ve been successful but I need a NO brainer install if there is such a thing for an old man! Any help, suggestions, and replies will be greatly appreciated,
Grant
You need to buy the radio and a vehicle specific mounting kit and a vehicle specific radio wiring harness.
The wiring is very straight forward.
The wiring harness for the vehicle just plugs into the plugs that come out of the back of your factory radio.
Your new radio will come with a harness that plugs into the back of the radio.
All wires are generally color coded and marked to make for easy attachment. (red to red and yellow to yellow etc.)
you can solder the wires together or take the easy way out and just use the red insulated butt splices to put the wires together.
The wiring harness you want for your truck is easy to find. Take a look at the main page on Crutchfield.com. There is a tool towards the bottom of the page that you can input your vehicle info and it will spit out all the parts and pieces that are compatible with your truck.
Do yourself a favor and stay away from Kenwood and JVC(Same company) I put one in there originally and it lasted 2 weeks before an error code came up and it would not work. Found out it is a very common issue.
hey thank you so much! I went on the Crutchfield site and ordered everything I needed and it even includes instructions too! I really appreciate you talking the time to reply to me,
Grant
I put this one in mine and the bluetooth works great. Comes with a mic. https://www.amazon.com/Alpine-UTE-73.../dp/B07BJM6H51
Thanks so much! I went to the Crutchfield Audio site and ordered a radio with everything I need to install it! I just hope the instructions are not too complicated! Thank you,
Grant
Did you get the factory radio removal tool? If not I believe it is available at walmart.
I did and have had the radio out a few times trying to get it going again! I wish I could find someone to rebuild it for me I would love to stay stock!
Grant
Thankfully my original radio is still working well. I bought a cheap $20 Bluetooth fm transmitter so I can keep the factory look and still have bluetooth functionality with no stupid cords hanging around.
I actually find most of the new aftermarket radios to be annoying with too many buttons, unnecessary features, blinking lights, and poor ergonomics. Unless you are an audiophile, I'd just pull an OEM one from a junkyard for a few bucks or have yours repaired.
Do you happen to know who or where I could send my stock radio to? I would prefer to go that route rather than buy something I have no idea how to operate!
Also.... thinking this through, I bet that there are plenty of vehicles Ford used the same radios on, other than the F-series trucks. Pull the radio you have in there again and look for the part number on it somewhere and just search eBay and google for that part number. I bet you find a nice one for under a hundred bucks.
what a great site! Thank you for sharing they have some products I am interested in! I appreciate your time!
