Rear end differential
Old Nov 7, 2020 | 07:17 PM
Art Lopez's Avatar
Art Lopez
I have a 2000 Ford van e150 van with a 3.31/8.8 rear end that I want to replace, what other year of van will fit my 2000 e150 as I can’t find the same year used for sale, can you help me?
Old Nov 8, 2020 | 08:47 PM
donjamer's Avatar
donjamer
Moved to appropriate forum...
Old Nov 8, 2020 | 09:32 PM
Conanski's Avatar
Conanski
The same 8.8 axle was used in the E150 from about 1991 to about 2010, and somewhere in the last 2-3 years of that period disc brakes were added, those would be a nice upgrade but other parts are required to get them working in your truck so it's not a direct swap. These axles were available with gear sets ranging from 3.08 to 4.10 and if your truck has one of the smaller motors consider getting a lower gear(numerically higher) for better performance and better overall fuel economy.
Old Nov 9, 2020 | 07:09 PM
maples01's Avatar
maples01
I can say 3.50 is a great overall gear, but if you live in the mountains look for 3.73, you'll not like the mileage of anything lower.
Old Nov 12, 2020 | 11:41 AM
baddad457's Avatar
baddad457
Also depends on what the tire diameter is too. Taller the tire, the lower the numerical ratio is at the pavement.
Old Nov 12, 2020 | 08:42 PM
maples01's Avatar
maples01
Yeah if you can tuck 33" tires in you'll want 3.73, that requires a lift for 1/2 ton, I see guys doing it with the 250 and 350, looks good, tho steering can be an issue, I was looking at a dually rear, wanted it to put in my E350, then I found it was a 4.63, way too low.
mickeybiel
New Member Introductions
Apr 18, 2015 05:38 PM
oldford64
Aug 6, 2001 08:02 AM
