Carburetor?
Old Nov 7, 2020 | 06:53 PM
ULTRA_MAGNUS's Avatar
ULTRA_MAGNUS
Carburetor?
I have a 1973 f-350 with a 390. The guy before me put a edelbrock intake and carb on it. I just finished a rebuild on the card and go to start it up and it won’t idle. It idles real rough then dies. If I rev it up it hesitates then sounds like it back fires. I had no extra parts and thought I did everything right. Where did I go wrong?
Old Nov 7, 2020 | 07:08 PM
caravaggio2000's Avatar
caravaggio2000
Take a pic of it so we can see the choke plate cold.
Turn the idle mixture screws (gently) all the way in and then two turns out. If it runs at that point, adjust the two screws a 1/4 at a time until you get your highest idle.
Old Nov 7, 2020 | 08:13 PM
ULTRA_MAGNUS
‘thanks. Pulled the screws out and sprayed carb clean in the holes then set the screws 1-1/2 turns. Idles once again. There was junk on the idle screw tips.
MineralStang
Jan 25, 2013 06:57 AM
Quantum77
Nov 21, 2010 05:17 PM
ddh1
17
Sep 12, 2009 11:28 AM
Max_'77F250
Jun 9, 2004 02:35 PM
390 guy
Dec 11, 2003 10:52 AM
