Serious brake issues
ABS light been on since I bought van.
replaced master cylinder yesterday , it was bleed.
started bleeding breaks at passenger rear using vacuum pump. Tried many times to get fluid out, nothing I did would let fluid flow when nipple was opened. I then had my brother pump the breaks old school and hold them as I opened nipple. After four or five tries finally fluid started flowing and I repeated until new fluid was flowing . Seemed like it was clogged or something. Moved onto the drivers rear , repeated the process , but this time no matter what I did I couldn’t get fluid to come through and gave up. This is my only vehicle for my family , can anyone please help me get my van fixed . Do I need new abs unit ? Anything you can help with us appreciated!
respectfully,
Mickey
respectfully,
Mickey
Why is this hose just sitting? Is it a breather ? Don’t see where it would go
I wouldn't replace an ABS unit until the wheel cylinders and calipers are inspected, cleaned, and repaired or replaced as needed.
Also what condition are the brake lines?
tha is so much for the help
So replaced bad driver side brake cylinder. Bled brakes from passenger rear, to drivers rear, passenger front and drivers front .
here where I need help ! Tried bleeding abs the same way I bled each wheel, but......! When I tried bleeding it no fluid would come out !
Is there a specific way to bleed the abs?
had my son pump breaks and hold and tried this five time with no fluid squirting out . I saw a dribble of fluid and I mean a tiny amount on the nipple , but nothing would come out .
My abs lights still on, can someone let me know if I need to bleed abs a specific way? Or does it need to be replaced .
AFAIK, unless you introduced air into the ABS system by running the master dry, you should be able to bleed the whole system starting at the RR, then LR, RF and LF.
Making sure you keep the master full and do not allow air in.
