Leaf spring help
Old Nov 7, 2020 | 10:07 AM
moosed's Avatar
moosed
Leaf spring help
2003 V10, 250K miles leaf springs in the front look almost flat, back are not that much better. Went to a shop and they quoted 1200. to re-arc all or 2500. to replace with new. Not looking to change the ride height, just want to stop the crashing at every little bump in the road. Recently replaced shocks, brakes, plugs, coils, rear bumper and hitch. Being a NY truck there rust on this but thankfully it passes the hammer test. Try to do most of the work myself but replacement of these isn't something I believe I can handle.
So what would you do?
Thanks
Tony
Old Nov 7, 2020 | 10:25 AM
Dweber85rc's Avatar
Dweber85rc
I certainly wouldn't spend 1200 to rearch almost 20 year old springs. 1200 should get you new oem springs and shocks+labor to install.
Old Nov 7, 2020 | 11:02 AM
moosed's Avatar
moosed
Agree don't want to re-arc the old springs, but 2500. sounds very high. In NY so everything is crazy expensive. Stuck between a rock and a hard place.
Old Nov 7, 2020 | 12:27 PM
thor363's Avatar
thor363
Junior at ATS, do it right.
Old Nov 7, 2020 | 01:32 PM
Vinny G-the EX man's Avatar
Vinny G-the EX man
Junior will hook you up with everything you need and if you don’t have anyone to install them it’s not that long a drive from NYC
Old Nov 7, 2020 | 05:59 PM
pirate4x4_camo's Avatar
pirate4x4_camo
They are supposed to be flat.
if the suspension is bottoming out your shocks are bad and a good chance you are missing at least 1 front bump stop. Replace them as well.
measure from the center of your hub to the bottom of the fender arc at all 4 corners. Front should be 23” rear 24”
more the 1” sag and they need replacing
Old Nov 8, 2020 | 06:40 AM
Rich Murphy's Avatar
Rich Murphy
Sorry, noobie. ATS?
***Disregard. Found it! For other noobs:
ATS Springs in Pennsylvania
Old Nov 8, 2020 | 07:37 AM
ASFC27FTFBQ's Avatar
ASFC27FTFBQ
ATS? Better stated: ATS!!!!!!!!
Junior helped me get the ultimate suspension for towing with my 2wd 6.8. He told me to not buy their front coils, but instead purchase OEM Z Codes.
Anytime a vendor tells me NOT to spend my money on their product, I’m in love/respect with for life.
Old Nov 8, 2020 | 07:43 AM
ASFC27FTFBQ
Sorry, I got too excited: autoandtrucksprings.com
Old Nov 13, 2020 | 06:15 PM
moosed's Avatar
moosed
Thanks for the replies...gonna install new bump stops on all corners and take it from there.
Tony
Old Nov 13, 2020 | 08:34 PM
pirate4x4_camo
Tony
likely needs shocks as well judging from your description.
try the KYB monomax, You will not be disappointed
LittleBlue79
Mar 26, 2017 07:00 AM
Jaaaaaaackman
Oct 22, 2016 10:25 PM
skapford
Sep 23, 2013 10:54 PM
wiggy762
Feb 6, 2008 07:55 PM
packrat56
Feb 27, 2006 05:31 PM
