disable camera switch??
Old Nov 6, 2020 | 06:54 AM
Fraser Addison's Avatar
Fraser Addison
Hey all,
I guess i'm a bit old school, but is there a way to arbitrarily disable the backup camera? Say some option for the camera switch?? I do use it sometimes for connecting to ball hitch, but more often than not, at night, its annoying as hell. The damn screen is too bright and over powering to see mirrors! Annoying AF...
Thanks in advance for advice!
Old Nov 6, 2020 | 08:52 AM
jwc410's Avatar
jwc410
I wish I could shut mine off at night it is too bright
Old Nov 6, 2020 | 11:24 AM
PentaPop's Avatar
PentaPop
I argued a bit with Ford corporate about this to no avail. They told me the backup camera law requires the camera to be on while the vehicle is in reverse. I sent them the text of the law which I interpret as; the camera must activate when the vehicle is shifted into reverse but it can then be turned off by the driver before actually moving in the reverse direction. They didn’t see it that way. My guess is, it’s a lawyer thing where nobody wants to have to answer why they’d build in a way to bypass a federally mandated safety device. Even if the bypass is specifically allowed by the law! You read it and see how you interpret it!
REQUIREMENT:
The rearview image meeting the requirements of S5.5.1 and S5.5.2 (S6.2.1 and S6.2.2) shall remain visible during the backing event until either:
• the driver modifies the view, or
• the vehicle direction selector is removed from the reverse position.
This test is conducted to verify that once the backing event is initiated (transmission selector into reverse gear), the rearview image cannot be extinguished by any means other than driver intervention which would include the vehicle direction selector being removed from the reverse position. Rearview image must extinguish by end of backing event.
Old Nov 6, 2020 | 01:21 PM
Fraser Addison
Frustrating... but i guess we are all SOL Damn...
Old Nov 6, 2020 | 04:03 PM
OffBalance's Avatar
OffBalance
I suppose if one was handy, one could potentially wire an upfitter switch to turn on/off the backlight for the LCD. Or maybe a relay connected to headlight circuit. I haven't yet poked around enough yet to know if backlight is a separate wire or is part of an on-board connection. If so you'd have to be really handy, but it's not out of the realm of possibility.
Old Nov 6, 2020 | 06:40 PM
d_smith84's Avatar
d_smith84
You could always just unplug the camera plug back at the tailgate.
Old Nov 6, 2020 | 06:49 PM
ATC_F350's Avatar
ATC_F350
Is the backup cam on it's own fuse? I wonder if it is, would it give an alert when going in reverse and the camera was off?
Old Nov 6, 2020 | 06:52 PM
fordman19762003's Avatar
fordman19762003
I believe there is a dummy plug in the trucks that you put on the camera harness when you unplug it if you remove the tailgate.
Old Nov 6, 2020 | 06:57 PM
d_smith84's Avatar
d_smith84
Yes there is
saddlethunder
Mar 3, 2019 08:52 PM
RailDawg
Jan 31, 2018 07:32 AM
Liquid10Rider
13
Sep 23, 2013 11:14 AM
INFRNL
Jan 30, 2013 01:17 AM
93 mix 'n match
1997 - 2003 F150
Oct 10, 2011 12:07 AM
