Coolant "spill"?
Old Nov 29, 2020 | 11:08 AM
annaleigh's Avatar
annaleigh
From what I have read on the subject since making my post, Spaznaut is correct that it is pressed down in the manifold and describes the most common method of repair. With the intake manifold left in place, you stand the chance of some of the old metal tube falling down inside the manifold and not being able to retrieve it.
This is apparently a problem what will resurface again in time. I read where one person had problems with a leak even after replacing the tube so they removed the manifold and tapped out the hole and threaded an adapter to just clamp a new length of heater hose directly to the adapter. Spaznaut could tell us if that might be easily done.
Also as JWA mentioned, you might want to try Ford for the original part. Perhaps they are all made by the same company though!
Also from what I have learned reading about your problem,,, the other hose was probably plugged off because of a leak in the other metal tube that runs under the intake manifold. It looks like there is a good bit of rust so if you are going to repair the heater so that it functions, I would think about replacing the heater core too.
kris b
Jun 14, 2020 04:37 PM
Logcabin
Dec 26, 2019 04:45 PM
coreyallan01
6.7L Power Stroke Diesel
Sep 23, 2019 04:43 PM
niykinick
Aug 14, 2018 07:01 AM
Amicus
Oct 28, 2017 10:13 AM
