Reverse level 2020?
Old Nov 2, 2020 | 09:32 PM
moore87's Avatar
moore87
Reverse level 2020?
Anyone do this yet? I’ve seen the earlier year models but haven’t seen a 2020 yet. Would really like the lower bed height
Old Nov 2, 2020 | 10:07 PM
cat-alac's Avatar
cat-alac
There was a thread a couple weeks back on this, sorry can’t remember the thread title. Thinking consensus was that because the 2020s only have 2 inch blocks in the back you can’t drop it a bunch. And there was some talk about pmf leveling kits.
Old Nov 3, 2020 | 06:19 AM
VA13FX4's Avatar
VA13FX4
I thought the 2020s had different blocks between the 250 & 350? 250 has shorter 2” and 350 has the taller blocks like the 17-19 trucks.
I can’t find that thread from a couple weeks ago!
Precision Metal Fabrication has high quality products and great customer service. I ordered shorter blocks through them.
Old Nov 3, 2020 | 08:00 AM
Lmhayes88's Avatar
Lmhayes88
My 2020 F-350 has a 2" block in the rear, as far as I have seen all the 2020's have a 2" rear block.
Old Nov 3, 2020 | 08:07 AM
VA13FX4's Avatar
VA13FX4
Oh! Well I clearly misread something. So to reverse level it would just require removing the block all together?
Old Nov 3, 2020 | 08:32 AM
Lmhayes88's Avatar
Lmhayes88
I have not done that personally but I don't see why that wouldn't work, it worked just fine on the older models.
Old Nov 4, 2020 | 09:21 PM
mothnuts's Avatar
mothnuts
I had a 1.5” PMF block that I had used on my ‘19 and then moved to my ‘20 when I traded.
Old Nov 4, 2020 | 09:23 PM
mothnuts's Avatar
mothnuts
Old Nov 7, 2020 | 09:47 AM
Jonzie59's Avatar
Jonzie59
I reversed leveled mine by removing the 2 inch blocks and adding a 3/4 inch steel plate. I fabricated the steel plate so Firestone air bags would fit directly on top of the plate, so I didn't need all the brackets that normally fit around the axle. Very clean and simple install. Biggest challenge for me was cutting the steel plate. I have a small hobby plasma cutter that would not cut the plate cleanly. This dropped the back of my truck at the trailer hitch 2 1/8 inches, with the tailgate down it dropped right at 3 inches. With the airbags I can go back up to the original height, or add more when towing a trailer, the best of all worlds. This mod has worked out great for me, no problems or issues, vibrations etc. I have some pictures of the plates on my phone, let me see if I can post them here.
FYI my truck is a 2020 F-350 Platinum SRW CCLB 4x4 6.7
Old Nov 7, 2020 | 10:19 AM
Jonzie59's Avatar
Jonzie59
Picture of the truck sitting on asphalt is after reverse level. Picture of truck sitting on concrete and asphalt is before reverse level.
Old Nov 7, 2020 | 10:49 AM
kluger's Avatar
kluger
Jonzie - I like your solution. Seems it combines the best of both by reducing bed height a bit and incorporating the airbag mount. Nice job. I'll be shopping for a 5er next spring to go with my new truck and I'll try to keep this in mind.
Old Nov 8, 2020 | 07:41 PM
Cory P's Avatar
Cory P
4wd High
I lowered the rear end of my 2020 F250 Tremor with PMF lower shackles. It was easy and took about 30 minutes.
https://www.pmfsuspension.com/1999-2...les_p_193.html
Old May 5, 2021 | 09:56 PM
dyoung4140's Avatar
dyoung4140
Jonzie- i am wanting to do something similar , but i noticed the factory block is tapered. Do you have any issues with vibrations at any speeds or while towing?
i also have a CC LB.
Old Apr 29, 2024 | 08:35 PM
Texas-Couyon's Avatar
Texas-Couyon
2nd Gear
Do you have any dimensions of the plates besides the thickness?
Or does anybody have any dimensions or drawings of the stock blocks to save me from pulling mine out to measure them. Thanks in advance
Old May 29, 2024 | 05:16 PM
Texas-Couyon
2nd Gear
Poor mans reverse level.
I finally got the time to reverse leveled my truck today. I did it the cheapest way I could 😅.
I work at a machine shop and machined me some 1” long heavy duty stainless washers with a 5/8 through hole to take up the extra length I would now have on the U bolts. I also have an Air Lift set of helper bags.
The whole process (short version):
All I had to do was loosen all the bolts to the helper bags. Remove the U bolt nuts and slide out my 2” blocks. Slide on my heavy duty washers and reinstall the nuts and tighten everything back up. The Air Lift kit has a radius cut out on the bottom of the bag pedestal that normally rests on the 2” block tang that matches the radius of the axle tube.
Now for the detailed version for anybody interested:
After blocking up the truck loosen all the helper bag bolts. Put a jack under the rear diff and completely removed the U bolt nuts. Lower the whole axle with the jack under the diff until you can slide out the 2” blocks. Lift the rear axle back up after removing the blocks until you can slide the lower plate for the U bolts back on. Slide on the heavy duty washers and start the U bolt nuts. Lift the axle up close to the bottom of the leaf springs. Use another jack under the front of the diff to get the correct angle for the **** on the bottom of the leaf springs to drop back into the location hole on axle mount. Tighten up the U bolt nuts to the torque spec (90ft lbs from what I have read) no lubrication in the threads. Tighten vertical bolts on the airbag mounts first to make sure they seat on the axle tube correctly. Tighten the U bolts that hold the airbag mount against the leaf springs and drop the truck back down.
