Posi Traction
Old Nov 2, 2020 | 01:20 PM
Chase Sharp's Avatar
Chase Sharp
Posi Traction
I have a 1994 Ford F-150 5.8L V8 (351). I was wondering if it has posi traction?
Old Nov 2, 2020 | 01:38 PM
GNR22's Avatar
GNR22
2 ways to tell. In the driver's door jamb, the tag should list an axle code. The axle code will tell you if it is a limited slip carrier. There should also be a small metal tag on the rear differential cover with the gear ratio. Many times this tag is gone or illegible so it is easier to just use the axle code on the door jamb.
Old Nov 2, 2020 | 04:09 PM
rla2005's Avatar
rla2005
Check the Axle Code listed on the b-pillar door jamb sticker.
If the Axle Code begins with a letter it's a factory limited slip rear axle.
Old Nov 2, 2020 | 04:13 PM
Nothing Special's Avatar
Nothing Special
Literally? No, it doesn't. Positraction is the name for a limited slip made by Eaton. Chevy used it, but Ford used TractionLok (or TracLoc or some other spelling variant).
But to see if you have a limited slip diff you can also jack up both back tires. With the trans in gear (or an auto in park) try turning one. If it turns pretty easily and the other tire turns backward it's either an open diff or a completely worn out limited slip. If it's hard to turn it's either a limited slip or a dragging brake.
Then put the trans in neutral. If it's still hard to turn it's probably a dragging brake. If it turns and the other side turns the same way it's probably a limited slip. And if it turns and the other side turns the opposite way it's probably an open diff.
Old Nov 6, 2020 | 12:59 PM
Chase Sharp
Posi Traction
Ok great everyone. Thanks for your help! I will definitely look to see
hatcatz
18
Mar 20, 2004 02:15 AM
stover007
Apr 3, 2002 06:37 PM
TDR
Jan 19, 2002 08:59 AM
