351 ho????????
Old Oct 22, 2003 | 09:45 PM
rustyolred27's Avatar
rustyolred27
351 ho????????
1987 f-150 4x4 351 h.o. v-8. what was the stock h.p. and torque numbers on this engine? also it has an auto tranny, which one? is the tranny an overdrive unit? what is the most likely t-case? haven't bought the truck yet or even driven it, just going on a word from a friend...............also it is a really good deal in my opinion.
Old Oct 22, 2003 | 09:54 PM
ford9658's Avatar
ford9658
Horsepower
I have a 1996 F-150 5.8(351W) and the ratings on it are 240hp@4200 RPM and 340@3200. You can tell if it is a Overdrive on the 87-91's if on the lower right hand side of the dash there is an overdrive button. And I think that on your truck the transfer cas is a Borg Warner 56
Old Oct 22, 2003 | 10:37 PM
rustyolred27
what tranny is this? e4od? is it a goog tranny? how good is the t-case?
Old Oct 23, 2003 | 07:19 AM
jwtaylor's Avatar
jwtaylor
If it happens to have a overdrive then its more likely than not a aod if it is a 3 speed it is probably a c6 which is a very good tranny in stock trim. Count the tranny bolts, or run the vin or there should be a code on the door of what tranny is in it. All the H.O. means is it has a 4 bbl intake and carb and more likely than not it has the E5TE heads which is a 67cc+/- head with a larger thermactor bump but in reality is identical to the mustang E7TE except they have smaller thermactor bump and smaller combustion chambers 64cc+/-. later
Old Oct 23, 2003 | 11:41 AM
Kemicalburns's Avatar
Kemicalburns
ford96. the 87-91's either had a C-6 or AOD tranny. if its the AOD it does not have a button on the dash. the dash mounted over drive button was for The E4OD tranny which didnt arrive till late 90. being that his is an 87/351 it more then likly has a C-6.
late
Rick_Fury
13
Aug 1, 2012 11:39 AM
hotrodder72
13
Mar 5, 2010 04:55 PM
Fordtough94
Apr 26, 2009 04:42 PM
bobman_00
Jan 19, 2004 05:05 PM
alwaysmessedup
Dec 5, 2002 08:58 PM
