Ever seen this before?
Old Oct 29, 2020 | 11:45 AM
Mixer man's Avatar
Mixer man
I've seen these engines converted into air compressors and vacuum pumps, but never run like this.
Old Oct 29, 2020 | 11:49 AM
52 Merc's Avatar
52 Merc
I don't think you'd want to do that for very long. I realize there's no combustion that would cause overheating, but the friction alone in the cylinders without water to keep everything moderated can't be good for anything.
Old Oct 29, 2020 | 12:06 PM
bigwin56f100's Avatar
bigwin56f100
I had the rockers and push tubes off a 292 once so I could crank it to see if I had oil flow from the head to the rocker shafts and the dang thing started and ran on 4 cylinders from the opposite bank
Old Oct 29, 2020 | 12:16 PM
Tedster9's Avatar
Tedster9
There's some kind of troubleshooting test they used to run back in the day, sort of like a cylinder contribution test. In a contribution test the exact RPM drop is recorded for each cylinder as the ignition is shorted out. In a healthy engine the drop should be uniform across all cylinders.
Can't remember which ones exactly, but the torture test involved idling a V8 on just two cylinders. Two cylinders in consecutive firing order if I remember right which I may not.
Old Oct 29, 2020 | 12:54 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The side that's running can be filled with water. There's no connection between the two banks except at the radiator.
Old Oct 29, 2020 | 01:41 PM
Mixer man's Avatar
Mixer man
Here's the air compressor. Couldn't find a vacuum pump video but it works in much the same way.
Old Oct 29, 2020 | 03:22 PM
bobbytnm's Avatar
bobbytnm
Roast em' if you got 'em
I've seen old air compressors, Ford 4cylinders, where it ran on 2 cylinders and the compressor was the other 2 cylinders.
Pretty cool
Old Oct 29, 2020 | 04:15 PM
49fordv8f4's Avatar
49fordv8f4
I have a Gordon-Smith model A compressor. It runs on the two end cylinders and pumps air with the center two. It will pump a lot of air. and runs smooth on two cylinders.
Mark
Old Oct 29, 2020 | 04:58 PM
85e150's Avatar
85e150
My dad had a Schramm with a Wisconsin V 4 that ran on two, pumped two. Loud, not so smooth but it pumped air, which was the object.....
Old Oct 29, 2020 | 05:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Mark
Old Oct 29, 2020 | 05:58 PM
49fordv8f4's Avatar
49fordv8f4
That's it, Ross. Mine needs a good cleaning. I haven't used it in a couple of years. The tank is 30-35 gallons and dated 1944. When the engine is warm you can completely empty the tank and start the engine, it will run the tank from 0 psi up to 120 psi and cycle down in 30 seconds. I was told that the construction companies that built the AlCan highway had a large fleet of these compressors and a shop that rebuilt them.
Mark
Old Oct 29, 2020 | 06:24 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm surprised they can get over 100 psi, must be 2-stage?
Old Oct 29, 2020 | 06:41 PM
Mixer man's Avatar
Mixer man
Not with two air cleaners and no intercooler. Single stage is good for 150-ish PSI. This one must be at least 75 CFM though. I'd be surprised if it was any less.
Old Oct 29, 2020 | 07:22 PM
49fordv8f4's Avatar
49fordv8f4
It is single stage. I have the governor set at 1600 rpm. The block is bored .100 over with stock stroke. I was told it would run a 90 lb jack hammer. It will rum a 1/2" sand blast nozzle with no problem.
Mark
Old Oct 29, 2020 | 09:43 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Model A engines had 4.2:1 compression ratios
