What dose hydroboost have to do with the parking brake?
It also has nothing to do wither drum drum or disc drum or disc disc.
Hydroboost takes the place of the vacuum asst power brake unit and that's it.
Now the master will make a difference wither drum drum or disc drum or disc disc.
Dave ----
Dave ----
Thank you. I am aware of what a hydro unit is and what it does. I've been running one for more than 5 years. I ask b/c I've NEVER read of anyone changing to hydroboost and keeping drums. The common upgrade is to swap from drum to disc, while upgrading to hydro. However, when a person makes the swap, they lose the p.brake. I would like to hear from the one-in-a-million guy who kept drums with hydro.
Cool. But I'm not interested in oem set-ups. I wondered if anyone has changed a dent side to hydro and kept the rear drums. Thanks.
The title of the thread is hydroboost with rear drums. Ask yourself what advantage there is to going to rear disc. Is it to say you did? Because it certainly isn't for improvement in braking performance. Not a single kit available uses the correct caliper bore size or pad size. You end up with what is perceived as improved braking solely because there is no slack in pad to disc. With drum there is marginal spacing that must be first overcome.
Lots of guys use GM front single piston calipers and pads on the Dana rears, you give up 60% of your friction contact area and actually lower your braking pressure because the caliper bore is too large. By the way I am the guy that runs hydro with rear drums.
Not a dent, but quite a few 66-77 Bronco's are using disk front and drum rear w/hydro. I'm actually considering doing that on my 71 because the vacuum assist is not getting it for me after I went to 35" tires. There are even a few Bronco owners that use hydro on their drum/drum setups with good results. I would use disk front / drum rear with hydro on my 75 with no qualms.
Mark.
I did mine with rear El Dorado p.brake calipers, but they work poorly and I'm tired of them. I wanted to hear from members who use the hydro with drums, 'cause I'm considering swapping back.
I have hb on my 79 w/rear drums. Don’t use the parking brake that much, because it’s automatic, but used the factory parking brake assembly. Uses junkyard parts, actually from an 06 Ford diesel hb and factory master. Then you just have to figure out the lines.
You know how many vehicles are on the road with hydroboost and rear drums? Lots of them as it was a very common setup.
From the factory no less.
Look at the early diesel trucks Ford & GM and even GM cars that ran diesel motors as they had to use Hydroboost.
BTW I had an 86 K5 Blazer (full size) with a 6.2 diesel Hydroboost disc / drum from the factory.
Other than the hydroboost seal going bad and dumping 2 systems full of fluid inside and the rug soaking it up it worked great for 230K miles.
Most of them miles pulling my car trailer to / from race tracks.
Dave ----
