Crank, no start
Old Oct 25, 2020 | 02:20 PM
Luis Mata's Avatar
Luis Mata
Crank, no start
Last week, I had drove my 6.0 to work and when I went to lunch, my truck only cranked. I noticed I had an oil pressure code come up but the truck eventually started after several minutes. Long story short, took it to a shop cause it wouldn’t turn back on. Was told I needed a starter. Had starter replaced but asked if they did any tests ( oil and/or fuel pressure test) but was told nothing and that no codes were present. That same day, I was stranded with a crank no start truck. When cold, it starts up fine, but today I let it go up to 165 degrees and turned it off. When starting, it only cranked. What could the issue be? Something being grounded? Oil pressure? Fuel or injector related?
Old Oct 25, 2020 | 02:25 PM
bismic's Avatar
bismic
What are you using to determine the 165 degree temperature value?
Will it give you ICP pressure and voltage as well as IPR % duty cycle?
Old Oct 25, 2020 | 02:27 PM
Luis Mata's Avatar
Luis Mata
I’m using an NGuage obd2 scanner
voltage shows to be good, over 12v
Old Oct 25, 2020 | 02:46 PM
bismic's Avatar
bismic
I was asking about the voltage output from the ICP sensor when cranking
Old Oct 25, 2020 | 04:59 PM
Luis Mata's Avatar
Luis Mata
That I do not know, my scanner doesn’t tell me
Old Oct 25, 2020 | 05:36 PM
bismic's Avatar
bismic
Do you have an OBDII adapter (ELM327)?
If so, download ForScan or Torque Pro.
Old Oct 25, 2020 | 05:40 PM
Luis Mata's Avatar
Luis Mata
I do not but I can get one
Old Oct 25, 2020 | 05:46 PM
bismic's Avatar
bismic
The BAFX adapter is about $25 and works well. The download is about $5. WiFi for iOS and BlueTooth for Android.
Old Oct 25, 2020 | 09:01 PM
Luis Mata's Avatar
Luis Mata
When I started up my truck, I did get a P2291 code but the shop I took it to, they said they couldn’t find any codes. I’m pretty sure the ICP or IPR or both are bad
Old Oct 26, 2020 | 01:53 AM
bismic's Avatar
bismic
That is why I asked for ICP data. You could try disconnecting the ICP sensor when it won't start, but it probably is more than just a sensor issue.
Old Oct 26, 2020 | 10:15 AM
Luis Mata's Avatar
Luis Mata
How would I go about on testing it? With truck off, remove the connector from the sensor and see if it starts after ? Or while running?
Old Oct 26, 2020 | 10:34 AM
Hartwig's Avatar
Hartwig
Mark meant remove the ICP connector key off. Then try to start.
Old Oct 26, 2020 | 11:18 AM
bismic's Avatar
bismic
Thanks Hartwig!
Old Oct 27, 2020 | 07:12 PM
Luis Mata's Avatar
Luis Mata
okay, I have the icp connector removed, so what am I supposed to do next? Start truck then what? Is it supposed to start or not? I’m just a bit confused lol
Old Oct 27, 2020 | 07:48 PM
bismic's Avatar
bismic
Yes, try to start with the sensor disconnected. If the sensor is bad, it will start that way.
