posted heads
Old Oct 24, 2020 | 12:50 PM
gumshoe's Avatar
gumshoe
posted heads
I have read several Y-block builds where posted heads were used. what is the difference between a "posted head" and a non posted head?
Old Oct 26, 2020 | 03:42 PM
charliemccraney's Avatar
charliemccraney
Posted heads have additional support over two of the combustion chambers. The other two chambers have that support because of the lower intake port. The 1957 G heads are the only heads where this may matter. The early ones were unposted. The later ones were posted. The change took place some time during the '57 model year. Any head from '58 on will be posted.
It's only really a concern with high compression race engines or boosted engines or possibly a high powered, on the ragged edge of "streetable," street engine. For most use cases, the post will not matter.
Old Oct 26, 2020 | 05:59 PM
gumshoe's Avatar
gumshoe
Thanks for the reply, I have mostly worked with later ford engines and when I read where a Y block was being built with posted heads, I thought what the heck are posted heads. thanks for the info.
46yblock
Feb 5, 2007 10:09 AM
scottie2hottie
Nov 25, 2004 11:11 PM
chris28
Apr 25, 2004 01:52 PM
Winchester
Mar 17, 2004 06:39 PM
