HELP!! Wheel bearing issue
Old Oct 23, 2020 | 08:36 PM
waldounit2's Avatar
waldounit2
So I'm replacing the wheel bearings on my 68 on the front passenger side and the hub will not spin freely the other side spins no problem but this side it seems to be hanging up and I have no clue what else to do any suggestions or help would be very appreciated
Old Oct 23, 2020 | 11:08 PM
resonateur's Avatar
resonateur
Did you replace the race in the hub along with the new bearing? (They should be changed as a set) Is the race driven into the hub completely? Back off the brake shoes so that they don't touch? Is the grease seal driven into the hub completely?
Old Oct 24, 2020 | 12:34 AM
waldounit2's Avatar
waldounit2
The race is still in the hub a nd breaks are completely backed off
Old Oct 24, 2020 | 12:12 PM
orich's Avatar
orich
Hmm did it spin before you messed with it?
Like said above did you install new inner and outer hub RACES ?
Is the new bearing have the same number and brand name ?
Your doing something wrong, what have you torqued the spindle bearing nut too ?
Did to spin the wheel back & fourth while tightening nut to seat bearing ?
Also did you check the wheel cyls to see if leaking. How roll back the dust boot if fluid dips out it need to be replaced.
Best not to rebuild old cylinders because they get moisture eaten up inside and don't seal good...
Orich
Old Oct 24, 2020 | 06:38 PM
waldounit2's Avatar
waldounit2
Orich
after some research wheel cylinder was bad as well as the bearings thats what was causing it to hang up
Old Oct 25, 2020 | 06:45 PM
resonateur's Avatar
resonateur
...If the bearing is bad or galled, so is the race...I have always replaced these as a set.
Old Oct 25, 2020 | 09:26 PM
GaryKip's Avatar
GaryKip
Glad you found the problem.
aaron cardona
1978 - 1996 Big Bronco
Oct 2, 2020 07:02 PM
busdriver47
Aug 10, 2015 08:44 AM
specializedcc
Jan 18, 2011 06:52 AM
fuelman
Aug 30, 2008 06:32 PM
bulldog3531
Jan 24, 2005 07:26 PM
