Transmission swap
Old Oct 22, 2020 | 09:13 PM
Topshot 14's Avatar
Topshot 14
Transmission swap
I'm looking to swap from an E4OD to a stronger 6 speed automatic transmission, i'm not an incredibly experienced mechanic so i'd appreciate sort of a rough guide of how to do it as well.
Old Oct 22, 2020 | 09:26 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Installing it isn't that hard. You'll need to make an adapter plate because there is no six speed with a bellhousing that bolts to a 7.3L. The hard part is finding a controller that will make that six speed shift correctly. I don't know of one.
Old Oct 23, 2020 | 10:59 AM
DaveMcLain's Avatar
DaveMcLain
Bauman has an aftermarket controller that can run a 6 speed automatic.
Old Oct 23, 2020 | 10:12 PM
Edgethis's Avatar
Edgethis
This is not an easy swap, even for an experienced mechanic. Beyond the physical swap and the issue of getting it to run properly, as mentioned.
Is there an issue with your E4OD?
Old Oct 23, 2020 | 11:36 PM
97-psd's Avatar
97-psd
The bauman setup is only designed for one transmission. The 2011 and newer 6speed from the f150. It is designed to run on older gas engines. You ‘might’ get it to run on the 7.3 but I doubt it would be close to good.
For the time and $$ I would get an overdrive unit instead.
Old Oct 24, 2020 | 07:36 AM
TheFecalFanatic's Avatar
TheFecalFanatic
Why not get a built E4OD? There are quite a few builders that do a great job, and it'll still bolt into place and run off your PCM for the shift strategy.
Old Oct 25, 2020 | 07:40 PM
Topshot 14's Avatar
Topshot 14
No, it just does some real heavy towing and I think a 6 speed would help it out.
Old Oct 25, 2020 | 07:46 PM
Mark Kovalsky
I think you'll find that it is less expensive to buy a newer truck with a six speed than it would be to install a six speed in your truck.
Maiden666
Oct 7, 2019 08:25 PM
Kj.keiscome
26
Jun 7, 2017 10:41 PM
michaelskerrett
Oct 22, 2002 11:57 PM
