Approximately 200 lbs. less towing. If you’re that close you probably should be buying a diesel. I bought one because I didn't want to go with a aftermarket lift kit that would void my factory warrenty.( I know about the Moss act, I have better things to do then send time in court.)
I'm perfectly happy the way my stock Tremor looks(less the TREMOR stickers).
I looked up today found some info on it but there was 2 different places and one had something a little different than the other. The dealer couldn稚 explain why!
It depends on what you really need it for. I pull a TT with my 2019 F150 now. The 3.5eb has the power to pull it without a problem, but the payload just doesn't do it. At 1672 payload, I eat that up with just tongue weight and 5 passengers.
I ordered my 2020 F350 Tremor with the 7.3 to use as my DD and replace my F150 as the tow rig.
