battery drain
Old Oct 20, 2020 | 01:10 PM
jniolon's Avatar
jniolon
old and in the way
battery drain
Need an electronics guru… I’m not smart enough to use my tools !!
I have a parasitic drain on my truck battery, over three-four days the battery is dead. I recharged it and am watching the voltage on a meter., In 24 hours it’s dropped from 12.21 to 11.89 volts… so… 4/10s of a volt…
I tried disconnecting all the power sources individually and the only one I see with a draw when the power is not on is the radio/usb charging ports. They are on the same power source in the console. I'm sure the radio needs it to
maintain the settings and the two usb ports have a led light in them...
Using a fluke 87 meter in series with the power and set on the mA scale I get a reading of 127.1 (or so) so that is 127 milliamps, right ?? That doesn’t seem like enough to draw down a 810 CCA car battery in three-four days, does it ??
What else could be causing this ?? I haven't gone thru every circuit on the fuse panel yet, it's a little hard to get to... don't they make a 'hickey-thing' that you use to replace the fuse and measure current draw... kinda looks like a fuse with wires attached ?? what's it called ??
john
Old Oct 20, 2020 | 01:27 PM
1956_F100's Avatar
1956_F100
Does your truck have an alternator on it? If so, they will drain the battery if there are bad diode(s) in the rectifier inside the alternator. Try disconnecting the alternator to see if the drain stops. An alternator will still charge with bad diode(s) when the engine is running, but usually not to it's full potential. I use a test light in series with either the battery positive or negative terminal and the cable to check for drain. If it lights up, that is enough current flow to drain the battery.
Old Oct 20, 2020 | 01:48 PM
jniolon's Avatar
jniolon
old and in the way
that's something I hadn 't considered. I have a one wire alternator.. if I pull the positive wire from the alternator terminal and use an ampmeter in series will it show the draw there ???
thanks
Old Oct 20, 2020 | 03:04 PM
1956_F100's Avatar
1956_F100
I'm not familiar with one wire alternators. But, alternators, when in good condition do not draw current when the engine is not running. I'd think if something is wrong with the alternator the draw at the battery would stop after disconnecting the one wire from the alternator. If it does, maybe contact the alternator mfg. to get more info on the alternator.
Old Oct 20, 2020 | 03:16 PM
raytasch's Avatar
raytasch
Believe Nothing
I suspect 56 F100 may be onto something. Try disconnecting the sense wire and see what happens. Chances are the alternator will still put out.
Indybeer's Avatar
Indybeer
If you have a parasitic drain from either your radio or USB port I would disconnect then one at a time to see which is causing the draw. One of them most likely has an internal short to ground.
cabindoc
6.7L Power Stroke Diesel
24
Oct 14, 2024 02:26 PM
Lincoln White
22
Mar 3, 2017 07:27 AM
w4gy
Aug 29, 2008 06:25 AM
DarkWolf40
Electrical Systems/Wiring
Dec 1, 2007 08:51 AM
nsshull
Aug 14, 2005 11:14 PM
