2017+ Super Duty The 2017+ Ford F250, F350, F450 and F550 Super Duty Pickup and Chassis Cab
Firestone still says there kits don’t work with FX4??
Old 10-19-2020, 07:05 AM
cameronskidoo's Avatar
cameronskidoo
cameronskidoo is offline
I’ve read the other posts in regards to this issue.
Here is my communication with Firestone
Old 10-19-2020, 09:05 AM
fleming23's Avatar
fleming23
fleming23 is offline
Maybe I was haphazard in my measuring, but my 2020 Platinum FX4 F350 was only around 40mm, and the 2712 did work on my truck. Or well....I installed it last week with no apparent issues anyway, haven't towed with it yet as my new trailer is in production.
The 2712 is the 7500 pound bag though, but I can't see why the 5k bags would be much/any different. Your 55mm height could be an issue I suppose as I'm not sure if I would pick the lower hold or the middle. I would think the middle would work, and just compress the bag a little more at rest. If you run 5 pounds in them and use the middle hole, you might see slightly elevated rear ride height, I am running mine empty for that reason.
Old 10-19-2020, 09:24 AM
Rich53's Avatar
Rich53
Rich53 is offline
Mine was also 40 mm, I put the same kit in mine, it is a 2020 F350 SRW 6.7L with FX4. They went in fine, I run 5 lbs in them, I do think the ride height is probably up just a bit, maybe 1/2"?
I don't believe FX4 would have any impact on the measured height, the FX4 is only a few features and skid plates, I don't believe in 2020 the shocks are different anymore. I did put Bilstein 5100's in shortly after purchase.
They have worked fantastic towing with an 800lb tongue weight.
Old 10-19-2020, 09:43 AM
Lamoon78's Avatar
Lamoon78
Lamoon78 is offline
The FX4 package shouldn’t matter if it works on a non FX4 it will work on a FX4
Old 10-19-2020, 11:49 AM
orion250's Avatar
orion250
orion250 is offline
How heavy are you towing? My father just bought a big toy hauler, 17,600 lbs GVWR, and we put stableloads on his truck. I have the 5000 lbs airbags on my truck, both trucks are identical, F-250's non High Capacity. I hate towing that trailer with just the airbags. The stableloads engage the overloads at ride height, so when you start lowering the trailer on to the hitch, it's already sitting on the overload spring. The airbags are squishy and bouncing and never allow the overloads to engage. I am going to get rid of my airbags and get the stableloads or a DIY version. Seriously look at this option if towing heavy.
Edit to add: Basically stating that the overload springs provide way more stability than the airbags do. Either sag and let your truck ride on the overload springs or buy the stableloads.
Old 10-19-2020, 12:27 PM
pantera77's Avatar
pantera77
pantera77 is offline
I recently installed the 2620's (the 5k springs) on my 20 250 FX4. I had no issues, measured at 40mm. I did replace the long carriage bolts they include with 5 1/2", 3/8 bolts instead, was just enough to get the nylocks fully seated.
Old 10-19-2020, 01:13 PM
Rich53's Avatar
Rich53
Rich53 is offline
Regarding stability, if you plumb the airbags with a common fill connection, without a shutoff valve between them, the airbags will transfer air from one to the other when you are cornering, thereby making the truck feel more tippy and less balanced. With separate fills or better common fill with a shut off valve in one side, so that once filled you can close it and isolate the two sides, the airsprings when inflated will provide more roll stiffness.
Old 10-19-2020, 01:36 PM
orion250's Avatar
orion250
orion250 is offline
My airbags are separate air fills. Also, my bags were aired up to 60 psi in my scenario above.
Old 10-19-2020, 03:31 PM
cameronskidoo
So you’re truck measures 40mm or did you install the bags at the 40mm setting?
Does your truck have the overload springs (camper pkg)?
Mine does not have overloads.
Old 10-19-2020, 04:02 PM
Bullitt390's Avatar
Bullitt390
Bullitt390 is offline
Certified Thread Hijacker
I've never experienced that in air bags.
Semi-trucks have a common fill for tractor and trailer as well.
Old 10-19-2020, 04:18 PM
Rich53's Avatar
Rich53
Rich53 is offline
My truck measured 40, but it is an F350, so full spring pack.
Old 10-19-2020, 07:33 PM
pantera77's Avatar
pantera77
Mine measured 40mm. I also do not have the factory overloads.
Old 10-19-2020, 07:59 PM
sleddinfool's Avatar
sleddinfool
sleddinfool is offline
I ordered a set of the 2620's for my truck.. (which was only built yesterday so I don't even have the truck yet) I talked to a guy at s.d. truck springs, he assured me firestone has it figured out and this one will work with the fx4 package...Unkown to me, my kids also bought me the same ones, lol. I do not feel like paying for shipping for the 34 pounds back to s.d.. So either I'll have spares of everything or I'm going to sell the extras. Kevin
Old 10-20-2020, 02:25 AM
mrbryhan's Avatar
mrbryhan
mrbryhan is offline
I bought the 2620 bags for my 2020 F-350 SRW CCLB FX4 but the bracket wouldn’t seat properly on the axle because of the hard brake lines being in the way. Firestone said I needed to bend the lines. Has anyone else had to do that as part of your installation?
Old 10-20-2020, 05:00 AM
Lamoon78's Avatar
Lamoon78
Lamoon78 is offline
I never experienced this either and I always have a load. I put bags on everything love them.
Quick Reply: Firestone still says there kits don’t work with FX4??
