Running Board Lights
Old Oct 17, 2020 | 09:46 PM
Rainmaker1's Avatar
Rainmaker1
I'm in the process of renewing my rear bumper and planning the running boards renew project. I will be having the boards coated with Bullet Liner as I did for the front bumper valence and doing for the rear bumper step pads.
While I have the boards off and having them coated, I want to replace the light housings, plugs, and harness. Since it's apart, I'll renew as much as possible. I've located the light housings made by Westin or Alpinetech. They look identical in the pictures, so they're probably made by the same company. I can't seem to find either a new harness, or concrete information on what bulb socket and plug to use. I'm trying to have everything prepared ahead.
Has anyone replaced their lights, and what did you use, how do you like the quality?
Old Oct 17, 2020 | 10:06 PM
agsmv1's Avatar
agsmv1
I got the OEM harness off of ebay, the westing housings and used 194 leds.
Old Oct 17, 2020 | 10:11 PM
Rainmaker1's Avatar
Rainmaker1
I checked on the wire harness and everywhere said they were discontinued. Please correct me if I'm in error.
  • Running Board wire harness left- YC3Z14408-DA
  • Running Board wire harness right-YC3Z14408-CA
Does anyone know if the Westin 27-9903 harness will work with my OEM running boards? It appears this could be my answer.
Old Oct 18, 2020 | 08:21 AM
Dweber85rc's Avatar
Dweber85rc
I got a replacement bulb connector with pigtail at napa. Not sure if that is whst you meant by harness or not.
Old Oct 18, 2020 | 05:33 PM
WY_'s Avatar
WY_
Do you by chance have the NAPA part numbers for the pigtail sockets? I have two dead ones and have not found replacements.
Thanks!
Old Oct 18, 2020 | 07:42 PM
Dweber85rc's Avatar
Dweber85rc
Thanks!
ECH EC291 . If I recall correctly this is the pigtail, the bulb socket plugs into this. If its the bulb socket then I'm not sure.
Old Oct 18, 2020 | 09:49 PM
agsmv1's Avatar
agsmv1
I may still have mine. I will check tomorrow and let you know. If you want them you can have them. the housings and pig tails...but let me check.
Old Oct 20, 2020 | 07:50 AM
Squirrel13's Avatar
Squirrel13
LAMP SOCKET - https://www.dormanproducts.com/p-44850-645-693.aspx
LAMP REPAIR HARNESS - https://www.dormanproducts.com/p-24862-84772.aspx
RUNNING BOARD HARNESS TO BODY CONNECTOR - WPT152
Old Oct 20, 2020 | 08:40 AM
WY_'s Avatar
WY_
Those are the ones.
Thank You Sir!
Old Oct 20, 2020 | 11:12 AM
Rainmaker1's Avatar
Rainmaker1
The OEM lamp housing F75Z-13707-BA and Ford wants your left arm for each.
I found two aftermarket providers Westin (27-9904) and Alpinetech. Apparently Alpinetech doesn't make them and I could only find two on Ebay. Does anyone know if the Westin will fit the OEM running boards?
I called Westin and they say their housing ONLY fits their boards and WILL NOT fit in the OEM boards.
I can't seem to find any good information on these.
Old Oct 20, 2020 | 03:06 PM
johntpr's Avatar
johntpr
I might take a gamble on those Westin ones. I just bought a Ford OEM one and they look the same.
raven_zilla
Aug 14, 2021 07:21 PM
dieselsubmariner
Nov 6, 2014 07:08 PM
hpwoee
May 5, 2014 11:21 AM
Alaska350V10
Nov 28, 2004 09:18 PM
Byrddog
Nov 20, 2004 07:39 PM
