Bed cover and ice
Old Oct 15, 2020 | 10:26 AM
eminence1963's Avatar
eminence1963
Bed cover and ice
Is there a product I can use to prevent my tailgate from sticking closed? Short of leaving it open think theft, or garage it, since it wont fit in the garage. Frost and ice prevent me from opening it in my neck of the woods. What are my options?
Old Oct 15, 2020 | 10:49 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
Never in 12 years on my 2006 F350 CCSB did I ever have an issue opening doors or tailgate ... UNLESS you are talking ice storms or freezing rain.
Can you give more detail ? Where do you live and how often does this happen during what weather ?
Is it the Latch/handle or the sides/bottom sticking ?
What to use depends on What needs to be freed and how often?
Old Oct 15, 2020 | 11:01 AM
eminence1963
Live in the Pacific North West So in the winter every day this is a problem. Ice snow freezing rain.Tail gate sticks to Bed cover.Its a electronic latch, so when you press the button to release tail gate it don't move. Last year I carried a pry stick to get it to open. PITA.
Old Oct 15, 2020 | 11:21 AM
seville009's Avatar
seville009
can you just cover it with a tarp or something when it’s parked? Pain to do, but other than that, the pry bar method you are doing is probably the next best simple method.
Old Oct 15, 2020 | 11:28 AM
losttrail's Avatar
losttrail
Being from MT, having lived with trucks in Texas, Illinois and Colorado, funny that the only place I've had this issue is Texas. Those north Texas ice storms are something.
Old Oct 15, 2020 | 11:53 AM
Lin19687's Avatar
Lin19687
Veteran: Navy
Ahhhh now I see. I've had my door frozen with 1/8" ice and there is enough room under the door to pull there and at the handle when that happens.
tail gate is tough. I too suggest a cover of some sort, but if you can blow dry the area of latch before you cover that might help.?
Also not sure if something like lithium grease would work... not sure if that is what it's called, white thick spray grease?
Old Oct 15, 2020 | 12:01 PM
mhoefer's Avatar
mhoefer
Cover and inside and out of flap on top of the tailgate needs a healthy coating of armor all or suitable, top of tailgate too. It doesn't stick. I am in Northern BC and do this all the time, never had them stick together.... sheds water and ice.
seville009's Avatar
seville009
one other idea - I keep a bottle of winter windshield washer fluid in a spray bottle in my plow truck. I spray it on my mirrors (which are too small to scrape) when they are iced up. It’s a slow melt, but it does help.
Old Oct 15, 2020 | 01:47 PM
TCNashville's Avatar
TCNashville
Go to Wal Mart and get a couple cans of CRC Ice-Off.
Old Oct 15, 2020 | 01:56 PM
eminence1963
Ok I'll try some of these
Old Oct 15, 2020 | 02:38 PM
Mike_in_STL's Avatar
Mike_in_STL
high idle and a heat proof hose off the exhaust pipe...use the hot air to melt the ice
Old Oct 15, 2020 | 04:51 PM
Lin19687's Avatar
Lin19687
Veteran: Navy
LOL, Just stop when you feel lightheaded hahahahaa
Old Oct 15, 2020 | 05:14 PM
mcmurm's Avatar
mcmurm
Lived in north Texas for a few years. Came from California and my first winter there I was clueless when my car was covered in an impenetrable sheet of ice.
@OP - I know you can buy cans of "de-icer" but I've never tried them. Not sure how well they work. In my opinion, it might be overkill, but would definitely be a neat little project. Run some low current heating elements along the bed where ice forms.
Old Oct 15, 2020 | 05:32 PM
losttrail's Avatar
losttrail
Now, I have had experience of having snow blown through the radiator so hard that it encased the entire engine in a block of packed snow (1956 F100) so that the engine couldn't turn over, had numerous vehicles buried in snow to the point of only seeing a large mound of snow.
Then there was Korea, but Uncle Sam's ride was a 60 ton beastie that didn't much care about such trivialities as weather.
Old Oct 16, 2020 | 06:32 AM
Pugga's Avatar
Pugga
Keep the seals lubed. I use Aerospace 303 Protectant but there are others you can use also. It seems to help prevent the ice from actually sticking to the seals. I have a Diamondback cover and haven't had it or the tailgate freeze shut on me yet (I also have a real tailgate handle, not the fancy electronic B.S. which, in my opinion, is one of the worst design decisions for a pickup but that's besides the point).
