Change permanent keypad access code?
Old Oct 13, 2020 | 01:23 AM
xxxn's Avatar
xxxn
Question Change permanent keypad access code?
Just got my first truck (and first Ford vehicle). It's a 2020 F-350 Lariat. I notice there is a permanent keypad access code in the manual pouch. Is it possible to change it? Seems like a security hole if it cannot be changed. Thanks!
Old Oct 13, 2020 | 03:21 AM
Scottyg2333's Avatar
Scottyg2333
Enter the factory code, followed by the 1-2 button and then enter the new code you want. Very easy to change. The permanent code is just that, permanent. Congrats on the new truck.
Old Oct 13, 2020 | 04:34 AM
mecdac's Avatar
mecdac
Seriously...
Old Oct 13, 2020 | 04:39 AM
VA13FX4's Avatar
VA13FX4
There’s no way to change the permanent code. Take the card out of the owners manual that has the code on it and keep it in your house. It’s not a security risk unless you tell all your friends, family and enemies the code. You can add additional codes to use that are easier to remember if you want.
Old Oct 13, 2020 | 06:04 AM
Poncho450's Avatar
Poncho450
This ⬆︎. It's in the owner's manual. I change it on every new truck.
Old Oct 13, 2020 | 07:15 AM
67L48's Avatar
67L48
Originally Posted by mecdac
Seriously...
Good luck with that. If people did, a third of this forum would evaporate!
Old Oct 13, 2020 | 01:49 PM
speakerfritz's Avatar
speakerfritz
you can do it thru the ford sync software menu
Old Oct 13, 2020 | 06:37 PM
VA13FX4's Avatar
VA13FX4
Not the permanent code. You can add and change additional codes, but. It the factory code.
Old Oct 13, 2020 | 09:40 PM
xxxn's Avatar
xxxn
Page 69 and 70 on the manual for 2020 model don't seem to mention the capability of changing permanent code. Of course people may argue the word permanent implies it cannot be changed. When I'm given a pre-created password, the first thing I do is to change it and save the new password in a password manager with two factor authentication. Sadly Ford doesn't allow changing it. The code could have been exposed in the factory or dealer. Guess I have to live with it like many other potential security holes.
Old Oct 13, 2020 | 09:52 PM
Flyct's Avatar
Flyct
FTE Community Team
If you ever lose the permanent code it is also printed on the back of one of the modules behind the passenger side fuse panel.
Here’s a video of a F150 location. It’s the same in the Super Duty
Old Oct 14, 2020 | 02:05 AM
VA13FX4's Avatar
VA13FX4
Yes, it could have been exposed at the factory or dealer. But they also have access to your Keys. If you’re going to be paranoid about it you should probably change out all the key sets. The dealer also has your address, so you might want to think about moving.
Old Oct 14, 2020 | 11:03 AM
jollyrogr's Avatar
jollyrogr
Haha yes. It's not paranoia if you know they're after you.
Old Oct 14, 2020 | 11:22 AM
C12H24's Avatar
C12H24
And, yes, sometimes there really are bugs on you.
Old Oct 14, 2020 | 01:31 PM
xxxn's Avatar
xxxn
A physical key is harder to get than a code. Physical key can be replaced but this permanent code cannot. This is like "a permanent ssn has been assigned to you and you cannot change it even it's leaked and exploited". I'd hope Ford could at least give an option to disable this code.
Old Oct 14, 2020 | 01:39 PM
OffBalance's Avatar
OffBalance
I really like the code entry. But I agree fully that the permanent code should be allowed to be disabled or made limited or time-consuming to use. It probably won't be long until our trucks have fingerprint, retina, or face-scanning like our phones! Another consideration is that there is software now that can create a physical key from a photo. So it is about the same security as the entry code. Everyone needs to make sure there are no pix on the internet that show their house key hanging off their belt loop!
