No start hot
Old Oct 12, 2020 | 09:44 PM
Markus Luukko's Avatar
Markus Luukko
No start hot
Having a no start hot issue. I recently installed injectors, and a known good SRP1.1 HPOP. Truck idles funny all the time and will not restart hot, the IPR maxes out and the ICP takes a while to move up to 400psi and once and a while will reach 500psi to start. Bought a new IPR for it and a new ICP sensor and the issue remains. I tested for injector o ring leaks thru the IPR hole with the special tool and I cannot find any when the truck is cold.
Only code is for the #7 injector high to low side open but I ohmed out everything and everything is around 3ohms.
As far as I can tell there is nothing else that could cause a no start hot.
Old Oct 12, 2020 | 11:07 PM
udsuth78's Avatar
udsuth78
Ok, new Motorcraft stuff? If yes then what's the level in hpop res. Have you double checked the hpop gear and bolt? After that I'd do some dead head tests, first pump alone then each head separate.
Old Oct 13, 2020 | 08:12 AM
Markus Luukko
Yes both are new motorcraft parts.
I checked the HPOP reservoir cold and it was less than an inch from the top.
i will check the gear but if it was that wouldn’t I constantly have a no start? The HPOP has been in for a few months now and only gave me issues after I did my injectors and cups.
Old Oct 13, 2020 | 09:30 AM
BWST's Avatar
BWST
Got Data?
Agree your HPOP gear is likely fine.
If the issue started after injectors/cups, that's where I'd start. If high pressure oil builds slowly, it would point to an injector O-ring leak, or defective IPR not closing enough to build pressure. I would think you'd catch it with your IPR hole pressure test though.
Do you have the original IPR to compare?
Old Oct 13, 2020 | 09:41 AM
Markus Luukko
I got rid of the original IPR, I guess I will start the truck back up and let it get hot to retest.
Just to make sure, I hooked up my air hose to the IPR air tool, and then turned up the regulator, to around 90psi. I let it sit for five minutes before quitting and nothing was leaking. That should be the correct way to test right?
Old Oct 13, 2020 | 09:51 AM
BWST's Avatar
BWST
Got Data?
I think so. I have not done it, but was reading this link with info on the procedure:
https://jj-motorsports.com/products/...-test-fittings
You can check and see if the middle O-ring has failed on an injector by looking in the fuel bowl for oil/bubbles during this test as well.
You can crank the pressure up to 150psi - that might help. It says "shop air", and this oil system pushes 3000psi. I'd crank it up. Maybe that's why you can't hear it - 90 psi might not be enough.
Old Oct 13, 2020 | 10:02 AM
Markus Luukko
I don’t have a fuel bowl on this truck, I went with a 444fab system cause of the larger injectors. When I drain the tank from my sump I only get clean diesel fuel with no trace of oil in it.
Old Oct 13, 2020 | 12:03 PM
udsuth78's Avatar
udsuth78
When I air tested my heads a couple months ago I had to use a stethoscope to track down a leak. But if the leak is that's small you should still be able to start the truck. Maybe get a sample of fuel from the return line wherever is convenient. If the oils brand new not sure how well it will show up but worth a try I suppose. Since you did the injector cups as well have you checked the Degas bottle
Old Oct 13, 2020 | 03:56 PM
Markus Luukko
So I went and fixed some wiring cause it looked kinda janky and I used the old IPR pigtail to apply full ground to the IPR and get a max ICP reading.
Well when I applied ground I got 15% IPR. Shouldn’t it be at 99% reading from the PCM?
EDIT: I’m an idiot, the PCM is reading the default %.
Any tips from here? The PCM commands the IPR to go up but as far as I can tell it isn’t actually up like commanded.
The HPOP got to 2700psi so I confirmed the pump is good.
Old Oct 13, 2020 | 05:09 PM
Markus Luukko
Just dead headed the pump, puts out over 3000psi.
Checked the passenger side, made 3000psi.
Checked the driver side, same thing over 3000psi.
wouldn’t I have noticed a leak from the injector o rings when I cranked the engine over cause 3000psi was injected into the heads?
Old Oct 14, 2020 | 07:27 AM
RigCity's Avatar
RigCity
My truck had the same issue not starting hot turned out to be a bad IPR
Old Oct 15, 2020 | 01:44 AM
udsuth78's Avatar
udsuth78
3000 is good enough for sure, and a leak large enough to cause a no start would show something at 3k. Have you ever checked the hpo res during the hot no start, seems like a long shot but who knows. You've also confirmed fuel # an cranking speed are what they should be?
Old Oct 15, 2020 | 09:39 AM
Markus Luukko
Turned out to be a bad injector out of the box
Old Oct 15, 2020 | 10:19 AM
HKusp's Avatar
HKusp
Thanks for reporting back and glad you got it figured out, but it's weird how 1 injector could/would cause a no-start. These trucks have been known to run pretty good on 7...
Old Oct 15, 2020 | 10:27 AM
BWST's Avatar
BWST
Got Data?
...Only code is for the #7 injector high to low side open...
I agree, that bad injector explains this symptom, but not the no start. I expect there's more to come here. Bad new IPR or related wiring is all that makes sense to me right now.
