code p0305
Old Oct 11, 2020 | 08:21 PM
Jerry Kendall's Avatar
Jerry Kendall
Cool code p0305
I own a 2013 F 150 with a 5.0 litre engine. Recently a check engine light came on so I had a friend put his diagnostic tool to work and it showed a misfire on cylinder 5 at idle. He cleared it and after a couple of days it was back. My first thought was spark plugs. I had 139K miles on it and it looked as though the plugs had never been changed. I bought the truck used so I wasn't sure. I changed the plugs, nothing changed. I couldn't feel any hesitation or miss while driving but it idled a little rough. My next thought was the coil, I should have just swapped #5's for one of the others to see if the coil was bad but I just bought another coil and replaced it. Nothing changed. Ok, must be the fuel injector, nope, changed that nothing changed. any ideas where to go next?
Old Oct 11, 2020 | 11:40 PM
Johnny Paycheck's Avatar
Johnny Paycheck
You need three things to avoid a misfire. Fuel, spark and compression. Check compression next.
Old Oct 12, 2020 | 09:52 AM
alloro's Avatar
alloro
Ditto on the compression check. If it checks out okay then you likely have a issue with the wires going to the injector or coil. As a last resort the ECM could be failing.
Old Oct 15, 2020 | 10:49 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Agree on compression, go after that next. Then what alloro said ^^^^^^^
Soccer85
Jul 8, 2019 07:10 PM
Dan Robertson
2004 - 2008 F150
Apr 8, 2017 05:12 AM
CounterMaker
Oct 6, 2009 04:43 PM
2jhanna
1997 - 2003 F150
Jan 21, 2009 03:24 PM
swhite005
1997 - 2003 F150
Dec 19, 2005 07:42 AM
