88 302.
Old Oct 16, 2020 | 06:58 PM
dremtofford's Avatar
dremtofford
tried it with the old switch it didn't work so i tried with the new switch. i could adjust for working in run or working in acc. this timing is a pain how do i do it.
Old Oct 17, 2020 | 07:43 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I don’t understand. There is no timing of anything at the switch. Plug the old switch into the harness and try starting the truck. The switch is the part at the lower column.
Below is the ignition lock cylinder
Ignition lock cylinder
Old Oct 23, 2020 | 10:53 PM
dremtofford
88 302
I got the timing. Right on the switch it will go to run and acc but the start part moves real difficult it won't go all the way into start but it runs now and I drove it home last night . that is when I found out there is no dash lights, I have head lights and tail lights but no dash light or signal lights, but the signal switch I know is bad and I will check the fuses before buying a new headlight switch. It ran great but I am not sure of my speed, no dash lights. My friend that was following said I. Was in excess of 65 woohoo.
Old Oct 24, 2020 | 07:51 PM
dremtofford
88 302
I used the trick to pull someone out of a ditch today and 4wd worked great when I got home I smelled antifreeze I looked under the hood and the radiator cap had come off or it was blown off not sure but it is back home now and still idles at 3000 rpm I will have to investigate more when I warms up a little.
Old Oct 27, 2020 | 03:24 PM
dremtofford
88 302
I think somewhere in the past the previous owner let all the preinstalled smoke out that's why I am having problems with my truck. Just saying.
Old Oct 30, 2020 | 10:44 PM
dremtofford
88 302
I bought a new starter/ign switch I will pick it up tomorrow I looked for the clutch switch and couldn't find it yet I will look some more tomorrow
Old Nov 25, 2020 | 03:31 PM
dremtofford
88 302
The previous owner said he replaced the ign locking cylinder, if he did it was with an older locking cylinder. It turns smooth bit might be worn out.
Old Apr 18, 2021 | 03:48 PM
dremtofford
found the clutch switch. it is up by the throttle pedal. i can see why the previous owner bypassed it with a button, what a pain.
Gene#1
Feb 9, 2019 07:39 AM
minnesotasix
Nov 29, 2005 09:05 PM
mauzer1
Sep 5, 2000 10:34 PM
RGAZ
May 8, 2000 12:43 PM
danm
Feb 14, 2000 09:08 PM
