‘87- 91. I’m not sure if the previous generation would work or not. What is the mysterious lever under your column that you mentioned in another thread? Would you post a picture?
Edit: picture of my ‘89 w/ manual transmission. My ‘87 auto trans does not have the key lock.
Purple arrow - push forward to tilt column Red arrow - push toward pass side to allow ignition cylinder to turn back from run to off to remove the key.
