Remove riveted frame brackets for painting?
Old Oct 7, 2020 | 03:07 PM
My4Fordtrucks's Avatar
My4Fordtrucks
I am going to get the new to me frame blasted and powder coated. Is it worth it to remove the spring and engine brackets that are riveted? The right side engine mount is bolted but the left is also riveted. Are they the same mount for both I-6 and V8 applications?
Old Oct 7, 2020 | 03:39 PM
Exwhyze's Avatar
Exwhyze
Removing hot rivets is not fun and somewhat dangerous depending on how caveman you're going. Personally I would not remove them, the bolts you'll replace them with have a minimal but existent chance of backing off, whereas if those rivets were going to shear they would likely have done so by now.
Old Oct 7, 2020 | 04:10 PM
My4Fordtrucks
Grind down the head and punch them out.
Does the driver’s side need to be changed if it had a 300 and I have a V8?
Old Oct 7, 2020 | 05:27 PM
mrollings53's Avatar
mrollings53
Cut an X in the rivet head, then use an air hammer and chisel to cut the head off, then punch the rivet out.
People have gone through and replaced the rivets with bolts before. The only reason I can think of to necessitate it is corrosion prevention. If you drive on salted roads it may be best to remove brackets to clean up underneath them, or uncover hidden rust damage.
Old Oct 7, 2020 | 06:39 PM
My4Fordtrucks
That would work if I had compressed air. I’m in the mid Atlantic so there is road salt and brine sprayed on the roads all Winter
afonda
17
Feb 1, 2020 05:29 AM
BuickBrian
Ford Truck Parts for Sale
Aug 14, 2013 05:27 PM
armyaviation
Oct 4, 2012 04:05 PM
Old_Crow
Jan 10, 2010 11:12 PM
thendrix
Feb 1, 2008 03:47 PM
