Frame support under the engine.. removal
Old Jan 31, 2020 | 07:57 AM
afonda's Avatar
afonda
I see this crossmember is riveted in place. Can the rivets be cut off and the crossmember removed?
I need to replace the oilpan.
Old Jan 31, 2020 | 08:01 AM
cjfarm11's Avatar
cjfarm11
I don’t think you can get it out even with the rivers removed. I have not tried but I looked at mine and I don’t think that idea will fly
Old Jan 31, 2020 | 08:05 AM
FordTruckNoob's Avatar
FordTruckNoob
Don't do it!! You can jack the engine high enough to get the oil pan out without cutting anything.
Old Jan 31, 2020 | 09:03 AM
SkySkiJason's Avatar
SkySkiJason
Attempting to replace oil pan in the truck is MUCH harder and 10x more likely to LEAK than doing it correctly.
The engine needs to come out and turned upside down if you just want to fix it one time.
I recommend a weld-in dipstick flange and have new oil pan sprayed with a pro bedliner product if the truck is still in the rust belt.
There are a couple of good write-ups here, but the front end does not need to come off and you can leave AC compressor and PS pump and bracket in the truck.
This is far less hassle and I’ve done dozens of them and never had a leak using Motorcraft TA31. No need to spend $80 on a gasket that still requires sealant....
Old Jan 31, 2020 | 03:43 PM
afonda's Avatar
afonda
Your engine is too pretty for 7.3.. hahaha
Old Jan 31, 2020 | 03:45 PM
afonda's Avatar
afonda
Your engine is too pretty...
Old Jan 31, 2020 | 04:24 PM
SkySkiJason
Thanks. You get to do that when you take yours out.
Its not that big of a deal. Really.
Old Jan 31, 2020 | 05:48 PM
Walleye Hunter's Avatar
Walleye Hunter
I have thought about that cross member too and I agree that it's probably not a good idea. For starters those rivets were probably smashed into place, with or without heat and will be harder than you would expect to get out.
Old Jan 31, 2020 | 06:17 PM
erickk120's Avatar
erickk120
I'm jealous of truck guys, you guys can still pull the engine without removing the cab. I wished I could do that in a van. Had I known this before, I would have gotten a truck, too late now :/
Old Jan 31, 2020 | 06:53 PM
Walleye Hunter
What makes you think you can't pull the engine out of a van?
Old Jan 31, 2020 | 07:05 PM
Dan V's Avatar
Dan V
Cuz when I look at that short little hood, I see no way it fits through there.
Old Jan 31, 2020 | 07:19 PM
Walleye Hunter
Well...I can't deny that that is an astute observation.
Old Jan 31, 2020 | 07:41 PM
afonda's Avatar
afonda
This is too funny...
Old Jan 31, 2020 | 08:50 PM
Sixgear's Avatar
Sixgear
how to remove oil pan without removing engine. install a moroso gasket exactly per their instructions.
he talks about it near the end of vid
Old Jan 31, 2020 | 08:55 PM
Sixgear's Avatar
Sixgear
In the factory service manual certain frame rivets are allowed to be removed and replaced with the correct size Grade 8 bolts and nuts and torqued.
I don't know if it is allowed with the cross member.
