Clutch Setup
Old Oct 7, 2020 | 01:05 PM
mikei16's Avatar
mikei16
Clutch Setup
I have a 1951 F3 pickup with flathead V8 I am installing Borg Warner T 5 5 speed trans. Can I use my OEM pressure plate and just try to find the right diameter clutch and spline size? Have anyone used a T5 trans?
Thanks
Mike
Old Oct 7, 2020 | 03:19 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is it an S10 T5? If so, usually the S10 disc is used with a stock 10" PP. I think the S10 disc is a 9.5", a little smaller than the stock 10". I imagine with you having an F-3, you may have an 11" clutch, tho?
Old Oct 7, 2020 | 05:06 PM
mikei16's Avatar
mikei16
Hi Ross, yes it is out of 1995 S10. I will see what I can get my hands on.
Thanks
Mike
Old Oct 8, 2020 | 05:32 AM
mikei16's Avatar
mikei16
Ross, it looks like the truck had an 11" clutch the flywheel surface is 13 1/4" the PP bolt holes are 3/8" in from the outer edge to the center of the bolt hole.
Old Oct 8, 2020 | 10:56 AM
ALBUQ F-1's Avatar
ALBUQ F-1
That sounds like an 11" clutch, but measure the PP surface to be sure. If you had a 4-sp crashbox or HD 3-sp you certainly had an 11". I don't know of anyone using an 11" PP with the S10 disc, could be there is another GM disc with the correct spline count and a larger diameter. Might be worth a call to Cornhuskers to see if they know.
You can have the flywheel re-drilled for the 10" PP, or try to find a good used one already drilled. Speedway does sell new flywheels drilled for that ($$). Re-drilling needs to be done accurately and correctly, the holes have a countersink to fit the PP bolts snugly (don't use hardware store bolts). You'll need a 10" PP for them to measure the bolt circle, too.
Old Oct 8, 2020 | 03:25 PM
mikei16's Avatar
mikei16
Thanks Ross, if I can’t find the right clutch, I will have my flywheel drilled. Thanks again
Mike
Old Oct 8, 2020 | 06:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I looked to see what Speedway has for their kits, also looked up a bunch of other cars that used the T5. Everything from 5.0 Mustangs to 5.7L Corvettes that used the T5 used a 9-1/4" 14-spline 1" shaft diameter disc. But Speedway has a note on their disc for this exact swap: "Not for use with Ford 11" PP".
Amazon Amazon
I remembered when I saw that that at least with Speedway's adapter, an 11" PP will not clear their adapter (it barely clears the 10", "some grinding may be required"). I don't see a way around using a 10" clutch.
Gorebs9589
Sep 15, 2019 07:18 AM
jmadsen
Dec 31, 2010 05:59 AM
Monsta
Feb 4, 2002 09:45 PM
