Clutch help!!
Old Sep 14, 2019 | 06:59 PM
Gorebs9589's Avatar
Gorebs9589
Clutch help!!
I have a 1986 f150 4x4 5.0 with a 4sp np435. It’s time to rebuild the trans so I figured now was a good time to do the other stuff. I know they use either a 10” or 11” clutch so I removed the trans today and then the clutch so I could measure what I had. It measures 10 3/8 inches. So almost 10.5”. Does that mean I have a 10” or an 11”? Just want to make sure I get the right replacement when I order. Thanks in advance.
Old Sep 14, 2019 | 07:49 PM
Franklin2's Avatar
Franklin2
You are measuring the friction disc or the pressure plate?
Old Sep 14, 2019 | 07:52 PM
Gorebs9589's Avatar
Gorebs9589
Friction disc
Old Sep 14, 2019 | 07:56 PM
Franklin2's Avatar
Franklin2
Don't know what to tell you. They say in the descriptions when I look them up they measure 10 inches or 11 inches.
Old Sep 14, 2019 | 07:57 PM
Franklin2's Avatar
Franklin2
P.S. Does your flywheel have two sets of bolt holes for the pressure plate? Some do. The outer set is for the 11 inch clutch, the inner set for the 10 inch clutch.
Old Sep 14, 2019 | 08:16 PM
Gorebs9589's Avatar
Gorebs9589
Yeah I looked them up and that’s all I could see too. I believe if does have both sets but I need to look. Didn’t really pay attention when I removed it. I will head back out to look.
Old Sep 14, 2019 | 08:44 PM
Gorebs9589's Avatar
Gorebs9589
So it appeared it was mounted to the flywheel on the outer most holes. The other threaded holes are closer to middle of the flywheel
Old Sep 15, 2019 | 07:18 AM
Franklin2's Avatar
Franklin2
Well, I would buy the 11 inch clutch. Even if you did have the 10 inch originally, why not buy the 11 inch as a upgrade? But it sounds like you may have had the 11 inch version if it was on the outer set of holes.
Mitch1407
15
Sep 6, 2012 09:21 PM
66crawler
Aug 20, 2012 07:38 PM
ghalacsy
Dec 29, 2011 09:29 PM
fisheasy
Apr 1, 2009 02:22 PM
jgib90
Aug 25, 2007 10:06 PM
