View Poll Results: Knock sensor
Knock sensor
50.00%
Knock sensor
0%
Knock sensor
50.00%
Knock sensor
0%
Voters: 2. You may not vote on this poll
Knock sensor
Old Oct 5, 2020 | 09:32 PM
Oilfieldtrash365's Avatar
Oilfieldtrash365
Knock sensor
I have a 1995 ford F-150 with a 4.9l motor and my knock sensor went out and ford no longer makes the knock sensor for my truck tring to find out if their is an online parts store or if I can bypass it and if I do that would it hurt my motor in the long run any thing would help thank you
Old Oct 6, 2020 | 04:30 AM
torq'ta 5 8's Avatar
torq'ta 5 8
Depends where you live, and still have emissions test, you will fail without it, JY could be only hope.
Old Oct 6, 2020 | 06:29 AM
rla2005's Avatar
rla2005
How do you know your knock sensor "went out"?
Old Oct 6, 2020 | 05:53 PM
Oilfieldtrash365
Knock sensor
How do you know that the knock sensor went out
I have tried timing up and down still running rich and on this truck since it has injectors if the knock sensor goes out it will make it run like a carbureted engine with the choke pulled half way out
Old Oct 6, 2020 | 05:55 PM
Oilfieldtrash365
Knock sensor
I live in Oklahoma and no we do not have state inspection here is JY an online store
Old Oct 6, 2020 | 10:09 PM
EllieMae94's Avatar
EllieMae94
I’ve had my knock sensor disconnected for the past 3 years and 50k miles and the engine runs great.
The knock sensor is probably fine. Have you checked for stored codes?
Old Oct 6, 2020 | 10:26 PM
Oilfieldtrash365
No nothing was popping up on the dash and it never ran like this be for I have had this truck since 2004
Old Oct 6, 2020 | 10:28 PM
Oilfieldtrash365
How did you disconnect the sensor is their anything special that I need to do?
Old Oct 7, 2020 | 06:07 AM
diggerrigger's Avatar
diggerrigger
I have heard this before. Can you explain or point to an explanation as to what exactly causes the rich condition?
Old Oct 7, 2020 | 06:57 AM
rla2005's Avatar
rla2005
I have never experienced or heard of what you are describing.
Old Oct 7, 2020 | 10:26 AM
My4Fordtrucks's Avatar
My4Fordtrucks
The check engine light does not need to be on for the computer have to fault codes. That is where you need to start looking. Have you pulled the vacuum hose off of the regulator to see if the diaphragm has ruptured? That will cause a rich condition since unmetered fuel is being drawn into the intake manifold.
Old Oct 7, 2020 | 12:43 PM
diggerrigger
@lisagoud 's thread from 2005. Where I first heard of the Knock Sensor / Rich Condition. HERE
Old Oct 7, 2020 | 02:23 PM
rla2005's Avatar
rla2005
It is an interesting read, but it's one thread out of hundreds on this forum related to the knock sensor. While I cannot discount the OP stated by installing a knock sensor their issue was resolved, I cast a leery eye until there are more data points. This vintage EEC-IV is not that smart to know if the sensor is there or not.
Old Oct 8, 2020 | 07:04 AM
Scndsin's Avatar
Scndsin
Been running a 5.0 MAF computer on my 5.8 that has no KS for over 2 years.
No place to screw it in, no codes, no pig-rich condition. Your results may vary.
ole88
Dec 4, 2011 06:57 AM
truckdude239
Mar 15, 2009 09:05 PM
rocket_6
May 10, 2006 04:20 PM
ken1mod
Aerostar
Sep 19, 2005 10:15 AM
Bob Ayers
3.0L V6
Jun 9, 2004 12:29 PM
