295/70 18 Cooper ST Maxx
So, I should be getting my tires this next Friday, and was just checking to see if you're still happy with them. I had a set on my old F350, and really like the way the wear.
Yes I'm happy with them. They did get louder as they wore, but no where near MT loud. I have 30k on them and probably will get another 10, but I have only rotated them once or I think 50k might would be seeable.
No. According my dealer the software they have only adjusts for/to stock settings. I wanted to lower the TPMS lower limit because I like 50psi in the rear. They tried and but they don't even have the option. I asked about tire size while the tech was in it and they only have stock sizes to choose from and there are no other settings. You will need to get Forscan and do it yourself.
Find someone with an Autel TS508 or better TPMS scanner. Run it as a 2018 and it should allow you to reset the TPMS set pressure. Forscan will do it with coding, but the TPMS tool is easier
I'm running those now. The dealer told me the same thing others have said, but I would need a VIN from a truck that had stock 20's they said to do it. Even then it would have just been close and not exact. I just changed it myself with Forscan and now it's dead on. Changing to the right hex value did affect the shift points. I like it a whole lot better now than when I was running it with the speedo uncorrected.
