PAYLOAD differences
I am new to the forum. If I mess up anything, I apologize.
I currently have a 2011 F250 SRW Crew Cab 4x4.Short Bed. Payload on the door jamb says 2213 pounds for passengers and cargo.
I am considering the purchase of a new 2020 F350 SRW 4x4 Crew Cab.Short Bed .
Ford's Payload Chart shows GVWR and associated PAYLOAD.
HOW does Ford achieve the higher Payload numbers with the various GVWR? ARE There PHYSICAL DIFFERENCES? Or something else?
Payload = GVWR minus Curb Weight.
The GVWR varies depending on the axles, suspension, wheels and tires of a particular truck configuration. To complicate things, the GVWR of a truck may be artificially derated to meet certain State's registration and/or insurance thresholds.
The curb weight of the truck will vary depending on how the truck is equipped.
Hope this helps.
There may be a lower one for XLs with 17 inch steel wheels. Gearing can affect the 7.3 gas rear axle unit installed.
You can derate from a higher number to 11,400 or 10,000 if applicable.
In a basic sense, yes there are differences in components: Axels, tires, springs, brakes, etc. that make up what the truck is capable of.
Then comes the paper game. For various reasons, taxes, licensing and so on, some trucks have their payload derated on paper. In other words, for example, two identical trucks might be built, both physically capable of the same loads. But one with 11,400 GVWR on the sticker and one with 10,000 on the sticker. The 2nd one can't legally carry the same load as the first. Once the OEM puts that sticker on the truck, it is near impossible to change it to regain the legal capacity lost to the derate.
Now... in order to get away with paying lower registration and not having to jump through other hoops in certain states, both of those truck can be ordered with a 10,000 lb GVWR. ABSOLUTELY NOTHING on the truck changes EXCEPT the sticker on the door. So the first truck is now 10,000 GVWR minus 7500 curb weight to equal a payload capacity of 2500 lbs, and the second truck is 10,000 GVWR minus 8000 lb curb weight for a 2k lb payload capacity.
It’s the exact same truck with the exact same capability, but the numbers are changed for registration purposes.
If you Really want to open a can of worms, start a thread asking if you can Legally carry over your payload capacity if the truck technically has the capability.
Add the axles together and register the gvwr at that number.
Weigh the truck the way you typically use it (without anything you intend to carry as payload, like a camper, etc, but with a full tank, the normal tools and passengers you normally carry, etc) and subtract what it weighs like that from the registered gvwr.
That is the current legal payload. This number fluctuates constantly as you use fuel, drop off or add passengers, add groceries, etc.
Don't exceed the registered gvwr, the individual axle ratings or tire ratings and you are legal.
All of this assumes the tires are rated at least as much as the axles. Tires rated higher than axle rating is better.
After lots of research and digging, it was concluded that a F250 and F350 tremor are exactly the same truck. (axles, diff, suspension, frame, etc) are all the same. The only difference was the sticker.
F250 - Ford Sterling M275 Axle rated at 6,200#
F350 - Ford & Dana rated at 7,280#
On p. 60, with the spring specs, all of the F250s (with the exception of a 4x2 Gas 176.0" Trailer Tow Heavy-Duty) and the F350 with the base 17" wheels (per the footnote), get the same springs rated at 6,340# @ a thickness of 4.71". All other SRW models of the F350 w/ 18" and 20" wheels get springs rated at 7,230# and a thickness of 5.15".
As far as I can tell, these differences in the rear end are the only things different between the F250 and F350, though I do recall watching a YouTube video of a Tremor test-drive at a Ford event where the Ford engineer mentioned that the F250 and F350 Tremors have the same springs, and I think he said the F250 gets the springs from the base F350, which I'm taking to mean the base springs of the model w/ 18" wheels, or the 7,230# springs. I don't know if that also means the F250 Tremor gets the axle from the F350, as there's nothing in the doc to indicate this. The only mention of 'Tremor' in the document is for the wheels, though I think 'ORV' in the weight charts refer to it.
I also want to note that this is mentioned in the footnote of the weight charts in this document -
Edit - Try this link if the PDF didn't attach - https://madocumentupload.marketingas...fb6b7&v5=False
The sunroof is a 99# hit on payload, btw. King Ranch and Lariat both have identical package weights at ~81#, though interestingly, the Platinum pkg is only ~15#. Lighter leather in the seats?
