Fuel Pump Installation
Old Oct 3, 2020 | 05:09 PM
arthall's Avatar
arthall
When a new fuel pump is installed on a 239 flathead V8, does it need to me primed in any way? Any need to fill the glass bowl with fuel? Or should cranking the engine be enough to start the pump flowing?
Old Oct 3, 2020 | 05:27 PM
seaves46's Avatar
seaves46
No need to prime the pump , if all hoses and connections on the suction side of the pump are ok , cranking the engine will get the pump flowing .
Old Oct 3, 2020 | 10:12 PM
Mixer man's Avatar
Mixer man
What Scott said.
Some misconceptions about the glass bowl; It's a sediment/decanting bowl. The inlet is in the top center of the housing where the fuel enters and swirls around and the heavy solids and water are settled out, and the fuel then passes up through a very fine screen into the outlet ports on each side of the inlet. In short, you can run out of gas and the bowl will still appear full.
jimzpsd
Mar 13, 2020 01:51 PM
