1978 - 1996 Big Bronco
Rear Disc Conversion
Old Oct 21, 2003 | 09:28 PM
i0n's Avatar
i0n
i had the opportunity to salvage the rear disc setup off of a 96 explorer today...will the rear disc setup from the 96 explorer work on my 8.8 rear in my 87 bronco?Any aftermarket ideas as well for rear disc setups ?Hope someone can clear the fog for me
Old Oct 22, 2003 | 01:10 AM
greystreak92's Avatar
greystreak92
Bolt pattern on the Expy. is smaller if I recall correctly. If memory serves, the Expy. is 5 on 4.5" and your Bronco is 5 on 5.5". Someone correct me if I am misleading here. Axles are a different number of splines as well which negates swapping axles to acheive correct bolt pattern. Wouldn't want to reduce the diameter of the bolt pattern anyway on the full size truck. Not to mention the obvious wheel dilemas.
Check this link http://tsmmfg.com/2530M.htm for TSM's rear disc conversion setup. A bit pricey if you buy the whole shootin' match but the basic kit is only $279.
fordtruckguy78
Jun 13, 2016 06:46 PM
flattie39
Mar 23, 2014 11:57 AM
bigdan1979f-250
Jan 7, 2013 01:32 PM
rangergirl94
Dec 12, 2012 09:03 AM
BobbyFord
Feb 23, 2005 05:47 PM
