Power window switch
Old Oct 1, 2020 | 06:24 PM
Yeti Dunlap's Avatar
Yeti Dunlap
Power window switch
Hi guys I have a 2000 Excursion with a V10 it's a limited. I replaced the switch module on the driver's side door panel. The window lock button was broke. Replace the switch but my other three windows will still not roll down by using their window controls. Checked fuses not sure what to check next anyone have any ideas. All help is appreciated thanks..
Old Oct 1, 2020 | 06:34 PM
WE3ZS's Avatar
WE3ZS
"Will still not roll down" did they function properly with the original switch module with the broken lock button or no, the way I'm reading it is that they didn't work prior to the new switch based on the above quote.
Old Oct 1, 2020 | 06:41 PM
Yeti Dunlap
Correct the window lock butt was broke on the old switch and all windows worked from the driver controls. But not from their controls..
With new control same outcome..
Old Oct 1, 2020 | 10:33 PM
2002Ex's Avatar
2002Ex
Do you have power at the other three controls?
Old Oct 3, 2020 | 07:27 AM
Yeti Dunlap
UPDATE !!
Found the problem. A yellow stripped wire was broke in the boot that goes from the door into the cab of the truck.
Had to add wire and fish it back through. Was a tight job but fixed the issue. Thanks for the help!!
Old Oct 4, 2020 | 01:12 PM
WE3ZS's Avatar
WE3ZS
Excellent! Thanks for the update.
Yeti Dunlap
Oct 1, 2020 06:25 PM
Eric White
Jun 27, 2012 12:47 PM
Mish
1997 - 2003 F150
Feb 24, 2010 07:36 PM
JethroF250
Nov 11, 2008 08:56 PM
