AMP Research Powersteps on a 2000 Excursion?
Old Oct 1, 2020 | 03:06 PM
csandstedt's Avatar
csandstedt
I'm about halfway through the install of AMP Research's Powersteps on my 2000 Excursion but I hit a roadblock installing the passenger side arm with the motor. The problem is that the motor and gearbox is hitting the AC lines so it won't fit on either the forward or rear position. I read through this install on a 2001 Ex and it seems to have worked on that year:
https://www.ford-trucks.com/forums/1...with-pics.html
Has anyone successfully installed the Powersteps on a 2000 Excursion?
Old Oct 1, 2020 | 05:25 PM
Dweber85rc's Avatar
Dweber85rc
Mount them a little lower?
Old Oct 1, 2020 | 08:11 PM
LandR's Avatar
LandR
Where did you find the best price on the amp power steps?
Old Oct 1, 2020 | 08:20 PM
Lance Helmert's Avatar
Lance Helmert
Looks like there is room above the lines. Gently reshape them to run up a little higher. Put carpet over the jaws of a pipe wrench and use it to put some gentle bends in the pipes.
Old Oct 2, 2020 | 12:54 PM
SmackDaddy's Avatar
SmackDaddy
Get your bend on
mxracer41
May 26, 2011 05:04 PM
JumpinJoe
May 23, 2009 01:28 PM
aldridgec
Jan 28, 2003 06:27 AM
