Sponsored by: Innova
Wiring an amp in 2000 excursion?
Old May 12, 2011 | 05:02 PM
mxracer41's Avatar
mxracer41
Hey guys, I'm new here and to be honest, I don't know a whole lot about these trucks. I am looking for a little advice on how to install an amp in my 2000 Ford Excursion. A few questions:
  • What is the best way to get the power wire through the firewall?
  • What is the best way to get the remote wire and RCA's to the radio without all of the wires showing?
Any help/advice is appreciated. Thanks!!
Old May 12, 2011 | 05:14 PM
fz1dave's Avatar
fz1dave
Super Duty
An existing grommet with other wires already coming through it. If there isn't enough room there, drill a new hole. If you drill, use a grommet that fits snugly against the cable.
Under the carpet and/or panels. The easiest run is usually along the kick panels. Pretty much depends on where the amp ends up.
Old May 12, 2011 | 05:16 PM
fz1dave's Avatar
fz1dave
Super Duty
Oops... almost forgot... welcome to FTE!
Check out the dedicated Excursion forum too!
Old May 12, 2011 | 10:15 PM
mxracer41's Avatar
mxracer41
Ok cool, thanks for the help. Do you have any idea which side of the firewall might be easier to get through? I have two batteries so I can run it on either side without any issues.
Old May 12, 2011 | 10:32 PM
fz1dave's Avatar
fz1dave
Super Duty
The drivers side is usually more accessible. There's always more room under that side. Here's a pic of the SD where I ran my 4 ga. into the cab. Found this empty grommet behind the sound proofing, probably for an accessory I don't have. I punched the hole and ran the cable. Done deal.
Sorry for the blurry last pic...
Old May 12, 2011 | 10:35 PM
fz1dave's Avatar
fz1dave
Super Duty
Here's an example of the space under the driver's side. There's so much room under the pedals I'm going to mount my 4 channel amp there. This is a quick mock up. Again I apologize for the pic. I overdid the flash a tad.
Old May 14, 2011 | 05:59 PM
mxracer41's Avatar
mxracer41
Wow awesome pics, thanks alot they helped a ton!!!! Already wired everything and hooked up the subs!
Old May 16, 2011 | 12:19 AM
fz1dave's Avatar
fz1dave
Super Duty
Cool! So where's your pics?
Old May 26, 2011 | 05:04 PM
mxracer41's Avatar
mxracer41
I will get some hopefully after I clean it up a bit! Right now as everything sits, I am running:
2 Rockford Fosgate P32D-10 subs (LOUD!)
Kenwood KAC-7205 1000 watt amp (not even close to enough power...)
Sony GT550UI head unit
Anyone want to give any suggestions for what settings to run on the head unit? I have played around with it and gotten it to a pretty good point but I am interested to see what you guys run yours at.. Thanks!
GCally
Jan 23, 2019 09:50 AM
FooFighter73
2015 - 2020 F150
Sep 21, 2015 02:59 PM
Reef Tech
Electrical Systems/Wiring
Oct 7, 2014 08:57 PM
mgmoore7
Mar 4, 2010 10:53 PM
Shepard
Jul 14, 2006 07:56 PM
