Clear Turnsignal Installation
Old Oct 21, 2003 | 08:57 PM
acerockola77's Avatar
acerockola77
I bought some Clear Turn signal lights off of Ebay, and now after going to install them, I can not seem to find a way to get to them in or even get the old ones out, I tried taking off the headlight door but something was holding it back. If anyone has any advice i would appreciate it.
Old Oct 21, 2003 | 09:42 PM
jesse460's Avatar
jesse460
they bolt in from inside the engine compartment through the core support i belive
Old Oct 22, 2003 | 01:40 AM
aikigod's Avatar
aikigod
There are four bolts holding the headlamp unit onto the truck. The first two are on top that everyone sees, and then there are two more inside. Look at the lights you purchased; the bolts on the back are the ones holding them in place (I believe they're held on by 10mm nuts). It'll be easier if you remove the coolant overflow tank and battery, then you can feel around for the bolt locations.
Mcroz
May 28, 2014 12:37 AM
Staveys150
Feb 28, 2011 04:50 AM
pauljackmax610
Jun 7, 2010 12:22 AM
PowerstrokeJunkie
Nov 26, 2006 08:13 AM
Lifesgud2
Oct 20, 2004 09:29 PM
