transmission interchange
Old Sep 29, 2020 | 04:41 PM
mwkobe's Avatar
mwkobe
I have a 96 7.3 with auto transmission will a 92 7.3 auto work In the 96?
Old Sep 29, 2020 | 07:14 PM
sevensecondsuv's Avatar
sevensecondsuv
I'm fairly certain it won't, assuming you're talking about the E4OD. If I remember correctly, there were some internal changes as well as changes to the EEC-IV control scheme in '93 or '94. I'm sure Mark K will be along soon with a definite answer.
If both trucks have the rarer C6 (mechanical 3-speed, non-electronic) automatic, then they probably would be a like for like swap. I don't think I've ever seen a powerstroke with a C6 though. However it was still available with any of the gas engines in 1996.
Old Sep 29, 2020 | 08:36 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
There are a few differences.
The '96 torque converter has six studs, the '92 had four studs.
If it is a four speed E4OD the solenoid bodies are different, though interchangeable. If you put the later body in the newer trans it will be fine. If it is a C6 (and the C6 was available with the Powerstroke though the 1996 model year) then I think the torque converter is the only difference.
Old Sep 30, 2020 | 06:53 AM
mwkobe's Avatar
mwkobe
can the T C be changed be or to use 92 in the 96
Old Sep 30, 2020 | 06:58 PM
Mark Kovalsky
Yes, you can change the torque converter. Other than the studs they are identical.
Old Oct 1, 2020 | 03:39 PM
tjc transport's Avatar
tjc transport
i ain't rite
yes the 92 E4OD trans will work in the 96 just fine, BUT you will have to use the newer 6 bolt torque converter for the 96.
we did this exact same swap 9 months ago and the truck runs perfectly.
jwitty
Sep 26, 2019 12:39 PM
DanielT28
19
Jul 29, 2014 08:15 PM
cmac75
May 3, 2008 11:50 AM
