Sponsored by: Real Truck
Fuel pressure drops to zero
Old Sep 28, 2020 | 07:17 PM
gabriell12123's Avatar
gabriell12123
1999 F250 5.4 starts and idles fine for a few minutes then fuel pressure randomly drops all the way down and motor dies. Pump,filter and injectors are all brand new. Never had this problem until today when I went to drop it off at the tranny shop
Old Oct 16, 2020 | 12:00 PM
gabriell12123
Bump still need help
Old Oct 18, 2020 | 01:20 AM
Craeshe's Avatar
Craeshe
This comment was deleted.
Old Oct 18, 2020 | 09:25 AM
99f350sd's Avatar
99f350sd
We need more info.. when did you change all that stuff and why?
Key on a few times with pressure gauge hooked up. does pressure hold up for 15 mins? What tests have you done?
Old Oct 19, 2020 | 03:52 PM
gabriell12123
Well I had a problem where the fuel rail was clogged by mud dobber nest I want to say the pump filter might be clogged up, pulled the filter and quite a bit of nasty stuff came out I put the inlet side back on and primed it a few times to flush it out and it’s running Better but still dies pretty often I tested the FPR and it’s good I assume it could always be electrical somewhere but I didn’t see any wires were rubbing on the frame or anything exposed it was a random all of sudden problem
Old Oct 20, 2020 | 10:16 AM
BigBlue99's Avatar
BigBlue99
How did a mud dobber get into the fuel rail?
If you have a lot of trash in the fuel tank then you might be clogging up the pump filter like you're thinking. i'd clean the tank if there is a bunch of stuff in there.
Old Oct 21, 2020 | 03:04 PM
gabriell12123
had the motor out for a month or so I could build it and I left the fuel rails dangling without plugging them
peerware
May 5, 2020 10:57 AM
Trucker man
6.4L Power Stroke Diesel
Jan 28, 2020 12:56 PM
berick
Nov 19, 2016 08:28 PM
florida_1959
May 17, 2010 01:08 PM
firemediceric
27
Dec 12, 2009 01:46 PM
