6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Starving for fuel
Old Jan 26, 2020 | 08:38 PM
Trucker man's Avatar
Trucker man
4wd Low
Starving for fuel
Hello everybody, In need of someone's opinion. I have a 2009 f-250 with the 6.4l, The problem I am having is during hard acceleration the engine will reach about 2500 rpm and then starts to bog down like it isn't getting enough fuel. It has new fuel filters and a new HFCM. Was able to monitor fuel rail pressure with the forscan software. When the problem would occur the commanded rail pressure would be about 24,000 psi but actual rail pressure would drop to around 1 to 2,000 psi. I need all the help I can get with this, thanks.
Old Jan 27, 2020 | 01:16 PM
speakerfritz's Avatar
speakerfritz
Have you ever found metal particles in the filter system?
Old Jan 27, 2020 | 08:57 PM
Trucker man
4wd Low
No, I have not seen any metal in either of the filters. I cut both open just to make sure.
Old Jan 28, 2020 | 09:45 AM
speakerfritz
There have been cases of oring snot being seated properly at the lower fuel conditioning module filter which sucks in air so check for that
there have been cases of defective fuel pressure sensors which is an easy replacement
ekse, hpfp would be suspect
Old Jan 28, 2020 | 11:44 AM
Trucker man
4wd Low
forgot to mention it earlier, but it also has a new rail pressure sensor. This problem started before we replaced any parts. Could the check valve in the secondary filter housing cause this problem?
Old Jan 28, 2020 | 12:56 PM
speakerfritz
There is no check valve in the 6.4 fuel system
if you have a new rail sensor, new fuel conditioning module and get Up lift pressure , and direct measurement of the fuel rail show the readings you are indicating.....you need to take it in to have the hpfp checked out.
But, if this is a new to you truck that you are trying to get going...and you obtained in this condition and are trying to get it going... we don’t know if this had a fuel system failure and a complete repair was done or not....metal fragments in the fuel system is almost impossible to get out ......
BigBlue92
1983 - 2012 Ranger & B-Series
Aug 15, 2012 10:30 PM
RdnckEMT25
Nov 2, 2010 07:42 PM
78250custom
May 22, 2009 10:05 AM
rriveroll
Jun 13, 2008 03:38 PM
muddawg
Jan 29, 2002 11:42 AM
