Sponsored by: Auxito
Brake expert needed
Old Sep 28, 2020 | 01:44 PM
96f150's Avatar
96f150
Brake expert needed
so my 01 has been having some issues for quite some time now with brakes. It (seems) that the rears arent working like they should. I was coming down a fairly long grade unloaded yesterday and by the bottom i could smell the brakes and my pedal was fading. This shouldnt be. I recently replaced my front rotors, pads, both front calipers 12/2019. The truck has always had a hard time breaking ever since i replaced the ABS unit 4 yrs ago. Im at a los for what to check next. I can pump the brakes a few times with key off and the pedal gets hard. Booster going bad? It feels like i really have to press the pedal down hard to get it to stop too.....Any advice?
Old Sep 28, 2020 | 09:20 PM
Bluegrass 7's Avatar
Bluegrass 7
A list of things you need to evaluate:
1 The Booster only hold enough vacuum for 3 to 4 pumps before the pedal goes hard without the motor running..
2. Is the heat generated at the front significantly higher than the rear or vice versa.? A possible tip off.
3. Are the pads the same on both ends?
4. What is the quality of the Pads. Don't expect very good performance from the low price spread.
Pads are of 3 grades of performance. Good beginning braking then fade off a bit. Need heat before good braking begins. and just plain no good.
All will fade if heated enough. The only way the pads get rid of heat is through the discs and boil the fluid in the caliper,
5. Are you able to bleed the rear calipers so there is no idea the line/s are blocked/
6. Sometimes the abs unit can be a problem.
Somewhere in all this is the answer or multiple reasons that stacked up..
On an old vehicle, the parts match can get away from the user and create issues that becomes perplexing until all thought out.
Good luck.
Old Sep 29, 2020 | 05:24 AM
96f150's Avatar
96f150
How long time wise, should the booster be holding vacuum? Just a few hours? I would assume that it leaks down overnight normally. I did gravity bleed the rears last night again. I believe I am going to replace the front pads. I cant remember what brand i put on there. I would have to say Napa? I will get an OEM set of pads
Old Sep 29, 2020 | 09:09 PM
96f150's Avatar
96f150
Could it also be an issue that my stone shields on my front brakes are completey rusted away and maybe their not cooling the rotors quick enough?
Old Sep 30, 2020 | 09:42 AM
jimgnj's Avatar
jimgnj
Try driving around in an open parking lot without braking very much. After some time get out and feel each rotor with your finger tips. If you find a hot one or two you know they are hanging up and dragging. Often overlooked are rubber brake lines collapsing from inside out. At 19 years old you can't go wrong changing out the rubber lines front and rear.
Old Sep 30, 2020 | 09:44 AM
alloro's Avatar
alloro
Brake fade is caused by excessive heat. When going down long grades it is advisable to downshift to reduce the need to brake as much, or when braking apply firm pressure in short braking bursts to allow cooling time instead of "riding" the brakes which doesn't allow cooling time.
Old Sep 30, 2020 | 05:14 PM
z 97ford1's Avatar
z 97ford1
I just replaced my rear brake shoes and WOW what a difference that made.
the braking is very tight now.
Old Oct 1, 2020 | 05:07 AM
96f150's Avatar
96f150
I have replaced the front rubber hoses about a year ago. I actaully did a side by side comparison and the old hoses definitly were getting smaller in diameter from swelling
Swisspsd
Sep 2, 2018 07:42 AM
mottrhed
May 8, 2018 06:35 PM
Jerrod710
25
Nov 13, 2016 02:18 PM
Thomas A
Oct 25, 2005 03:42 PM
Fuzion01
Oct 24, 2004 02:27 PM
